Use OEM wheels with winter and summer set up and swap every year?
Old Oct 1, 2019 | 11:10 PM
VaserC63S's Avatar
2015 Range Rover Sport Autobiography; 2019 AMG E63S; 2021 Range Rover HSE Westminister
Question Use OEM wheels with winter and summer set up and swap every year?
Who is using their OEM wheels with two sets of tires winter / summer and swapping them. Is this reasonable option and what are the downsides?
Old Oct 1, 2019 | 11:54 PM
dav461's Avatar
GTR
I use same.
Downsides : more time on tire fitting, extra cost for alignment
if you got very heavy winters with lots of snow and non cleaned roads, its better to go with 19" instead of 20" for better grip.
Old Oct 2, 2019 | 12:29 PM
Mandarin's Avatar
e63s
I used to have 2 sets of tires with stock wheels but found it takes lots of time to swap tires twice a year, also not that cheap. $120 twice a year + $200 an alignment twice a year. I bought 2nd set of wheels and wrapped OEM wheels with snow tires, now I can change wheels whenever I need myself and should not ride on dry pavement with snow tires with temperatures over 32F.
Old Oct 2, 2019 | 08:22 PM
Gerry_T's Avatar
E53 Cabriolet
I bought 3rd party wheels & OEM recommended snows and couldn’t be happier. Remember snows have better adhesion then summers any time the temp is less than 45F. No need to worry about switching out snows when it goes above 32.
Old Oct 3, 2019 | 05:16 AM
VaserC63S's Avatar
I swapped my stock Dunlop’s for Michelin AS3+ on my C63S and was very happy with them. They don’t have those for this car unfortunately. That’s why the dilemma. Am considering Bridgestone pontenzas all seasons. I much prefer one set for year round though I’ll say love these PS4S for summer.
Old Oct 3, 2019 | 05:58 AM
imack's Avatar
2020 AMG E63S Wagon, 2021 Subaru Outback Limited XT
Just curious, what are the OEM recommended winter tires?
Ivan MacKenzie.
Old Oct 3, 2019 | 10:08 AM
Gerry_T's Avatar
E53 Cabriolet
They recommended moving down to 19 inch rims & using the Pirelli Winter Sottozero 3 runflats
Old Oct 3, 2019 | 10:59 AM
imack's Avatar
When I searched at tirerack, they indicated the following sizes: 265/40-19 front, 295/35-19 rear. Are these the sizes you're running?
Ivan MacKenzie.
Old Oct 3, 2019 | 12:21 PM
24Hours's Avatar
2019 E63S wagon; 2016 Landrover Landmark
Unless you have the CCB... then only 20" will work
Old Oct 3, 2019 | 12:44 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Also might not be ideal for the tire beads and materials inside to be stretched so many times over its life.
Old Oct 3, 2019 | 04:28 PM
Gerry_T's Avatar
E53 Cabriolet
I’m running the 265/40’s on all 4 wheels. That’s how Mercedes built their kit. It also allows the tires to be rotated
Old Oct 3, 2019 | 05:08 PM
Carac's Avatar
2018 E63S Wagon
The OEM winter tire 19s clear the CCBs.
Old Oct 4, 2019 | 09:09 AM
Pioneer222's Avatar
W213 AMG 2019 E63S Wagon
Tirerack recomend a 19 square set up so we did 265x40 19s all the way around... on some aftermarket wheels also from tirerack. No issues around the calipers. Perfect fit... I thought I would need spacers for look due to not having 295s on the back but they looked fine and the MB dealer switching out the wheels for me recommended not doing spacers... mostly because they said you would just sling more crud down the rear of the car.
Old Oct 4, 2019 | 09:34 AM
imack's Avatar
Any chance you can provide a link to the wheels you purchased at tirerack?
Ivan MacKenzie.
Old Oct 4, 2019 | 12:20 PM
Pioneer222's Avatar
Ivan MacKenzie.
They were called Flow One brand, Model "F1" - funny if I search by wheels for an E63 they do not come up... but if you go through the winter tire and wheel packages.. for and E63 they come up... here is a pic I put in another thread today called "winters". Hope this helps.
Old Oct 14, 2019 | 11:39 PM
amgliturbo's Avatar
AMG E63s
@Carac Do you know for sure that 19 inch wheels can be used with CCBs and if so do you know the size of the OEM winter wheel package--any help would be appreciated. Also wondering how the E63s does in snow with proper snow tires.
Old Oct 15, 2019 | 12:21 AM
Carac's Avatar
2018 E63S Wagon
Another user here posted pics of them clearing his CCBs a while back:
Old Oct 15, 2019 | 02:48 PM
amgliturbo's Avatar
AMG E63s
Thanks Carac--this is helpful but the OEM wheels are pricey and I am not thrilled with the look of the OEM 19" wheels. I am wondering whether anyone has used any 19" non-OEM wheels with the CCBs for their snows. I wouldn't have thought that different 19" wheels had significantly different inner circumferences such that they would cause problems with the CCB discs/calipers but maybe I am wrong.
Old Oct 15, 2019 | 03:01 PM
amgliturbo's Avatar
AMG E63s
24Hours--I remember having read somewhere else on this forum that you need to use 20" wheels if you have CCBs, which I do, but Carac posted a pic of the OEM 19" wheel with CCBs--do you know whether the OEM wheel is different than most aftermarket wheels such that they will cause problems with the CCB disk or caliper?
Old Oct 15, 2019 | 10:40 PM
Gerry_T's Avatar
E53 Cabriolet
I was able to find after market 19 inch wheels that worked for my snows, but it required a tire guy that knew what he was doing and willingness to physically try the rims to make sure they work on the car. Of the 3 rims he ordered in to try, only 1 worked.
Old Oct 16, 2019 | 12:45 AM
amgliturbo's Avatar
AMG E63s
Gerry T --What wheels did he suggest--Can you give me a link to the wheels that you purchased. That would be a great help and thanks in advance.
Old Oct 16, 2019 | 08:07 PM
Gerry_T's Avatar
E53 Cabriolet
Opti Alloys S507
Old Oct 16, 2019 | 08:56 PM
Wolfman's Avatar
Super Moderator
The front CCB's on the S/E/SL/GT models are all the same SL rotors and thus fit 19" wheels as shown on the pic from AMGliturbo. However, not every 19" wheel may fit based on inner barrel diameter/offsets. The E63s on dedicated snows drives like a tank. Here is our winter beater
We used the same wheels only because we have the wheel/tire protection (simple for damages) and they look decent.
Old Oct 17, 2019 | 09:05 AM
amgliturbo's Avatar
AMG E63s
Opti Alloys S507
Thank you Gerry T.
Old Oct 17, 2019 | 09:08 AM
amgliturbo's Avatar
AMG E63s
Thank you Wolfman--I hadn't thought about my wheel and tire insurance. I am assuming that the insurer will cover the wheel damage but not damage to an aftermarket snow tire. What snow tire did you go with and what sizes?
