Idle Vibration
Idle Vibration
I have a 2018 E63s with 13k miles on it. I’m getting intermittent cabin floor and steering wheel vibrations at idle when in gear and at a stop light. Vibration immediately goes away as soon as the car starts moving. It also goes away when I put it in neutral or park. Sometimes the vibration is completely gone and sometimes it’s very prominent. Happens in both comfort and sport modes. The vibration is definitely noticeable by both front passengers but it’s nothing too crazy. Dealer inspected the mounts and they seem to be alright. Their official response was that this is normal in 4matic cars with V8 engines and MCT transmission with no torque converter and that I should just live with it. Is this vibration normal? Anyone else experience this? I got this car 2 weeks ago so I don’t know if it had the vibration before.
UPDATE: Noticed today that it only happens when I apply the brakes reeeally slowly and then come to a stop. Doesn’t happen when I depressed the brake pedal more abruptly. Also noticed today that the vibration goes away when I turn the steering wheel slightly in any direction.
Received 1,913 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
At a stop wet clutch should disengage at a total stop, then the vibes go away, sometimes it'll remain slightly engaged, such as in mild application of the brakes and cause the vibes
I have has 3 of these 213’s and the last one was the only one to vibrate. It was bad enough like yours at first that my passengers commented. It took awhile but service made go away for a bit by upping the idle a bit. It eventually came back but not as bad. The first two 18’s I had were smooth. I dumped the 19 because they couldn’t figure it out and it drove me nuts
Yeah this is pretty much what’s going on. I guess I’ll just have to get used to this. Thanks!
Could it be the Dynamic engine mounts? I believe the mounts firm up in Sport & Sport+
I notice a rough idle on cold start at times even in comfort, but usually goes away when engine is warm.
Can you explain , who fix it , what was their reasoning to replace the cv axle .
They got lucky or they knew what they were doing?
So you have to have specific symptoms. First it only happens in D and R with brakes applied and it goes away if you rotate your steering wheel in both directions while standing still. You can diagnose which side axle it is by lifting left or right wheel with a jack. If the vibration stops immediately as soon as the tire is slightly off the ground it is your axle that's the culprit. All 4matic cars can potentially have this problem and there are a few threads about it on the forums. When there's play in the inner CV axle or if the inner CV joint was rebuilt incorrectly (tripod cv joint) it causes vibration while idle. I could have just tried rebuilding mine but I decided to play it safe and just replace it all together. I have been trying to diagnose my vibration for almost a year and visited multiple MB dealerships, none of them could figure it out. After finding people with similar symptoms on the forums I was finally able to convince the dealership that it's the axle. (They were having a hard time believing it could be the axle causing the vibration).
The following 4 users liked this post by RF300:
19 E63s, 23 M3 compX, B9 SQ5
Rover338 (05-01-2024)
19 E63s(wifeys) & a 21 GLE580
I had a very similar problem years ago on the previous model E63 and it was because it had too much oil. I took out about half a liter and it was fine. Probably not the same fix but it is weird how some things affect these cars.
Good luck.
Good luck.
Vibration on steering wheel after car stop
Steering vibration at idle
I’m experiencing same issue on my 2018 s63 with 30k.
exacly the same. Car is at dealerships and they say is fine.
this is not normal. I have a gle 63s with 30k as well and this car does not do that.
any suggestions for fixing it.??
QUOTE=RF300;8238421]So you have to have specific symptoms. First it only happens in D and R with brakes applied and it goes away if you rotate your steering wheel in both directions while standing still. You can diagnose which side axle it is by lifting left or right wheel with a jack. If the vibration stops immediately as soon as the tire is slightly off the ground it is your axle that's the culprit. All 4matic cars can potentially have this problem and there are a few threads about it on the forums. When there's play in the inner CV axle or if the inner CV joint was rebuilt incorrectly (tripod cv joint) it causes vibration while idle. I could have just tried rebuilding mine but I decided to play it safe and just replace it all together. I have been trying to diagnose my vibration for almost a year and visited multiple MB dealerships, none of them could figure it out. After finding people with similar symptoms on the forums I was finally able to convince the dealership that it's the axle. (They were having a hard time believing it could be the axle causing the vibration).[/QUOTE]
This thread took an interesting turn, hmm.
I have a E43 and a couple of months ago I started getting the idle vibrations/mild shaking. I initially assumed it was the motor mounts after doing multiple 3000 RPM launches, but hadn't really had the time to look into it.
About 2 weeks ago, I saw a small puddle of grease on my garage floor directly under my LF suspension. I jacked it up and the outboard CV boot is bad and pushing the grease out. So I will soon be replacing my LF axle.
I can't really understand how the idle vibration can be linked the the axle/CV joint, as at idle, the axle is not moving but I'll surely see for sure soon when I replace the axle.
go fast grocery getter wagon
A failed boot now is just replacing the whole axle assembly, same is what I did on my W205.
I do most of my own work on my cars but this is something I'd rather pay someone else to do. I'm probably looking at $2000-$2500 (OEM axle assembly done by an indy).
Ah, okay thanks for sharing that. Makes me wonder if the LF is some kind of trend. At least it seems for me, my W205 LF boot failed also.
Maybe whatever noise it may be making is muffled by the rubber boot? I guess I'll know for sure when I get the axle replaced.
I'll make sure to post here either way.
