annoying tire pressure message
Old May 9, 2020 | 08:40 AM
fahad alamiry's Avatar
2018 E63s
every once in a while ( every 3 days ) i get the “please correct tire pressure” and it only appears when i drive the car for a certain period of time, i am currently sitting on 35 psi front and 34 rear ( warmed up ) so is it normal to get this message many times or i am doing something wrong or it is an issue related to the tires? thankyou
Old May 9, 2020 | 08:41 AM
2018 E63s
Old May 9, 2020 | 04:16 PM
Sixpaqs's Avatar
2020 E63S Wagon, 2021 GLE450
MB recommends 41psi for the front tires and 36 for the rears. At least in my wagon. Any reason you keep the fronts so low? You can adjust the tire pressures on the tire pressure monitor in the car to accept those tire pressures as normal, but they are lower than MB recommends.
Old May 9, 2020 | 04:20 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Are they recommending 41PSI for MPG? I am struggling to come up with another reason.
I had two W204s in the past - one a 2011, one a 2014, same wheel/tire setup but the 2014 recommended much higher pressure. The 2011 was something like 30/33 and the 2014 36/39. Something crazy like that. Made me think they were after better efficiency ratings.
Old May 9, 2020 | 04:41 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
There's not a lot of rubber between the street and the rim. At the lower pressure my guess is there is a higher likelihood of bending a rim after striking a pothole.
The tire pressure rating also has to do with load (number of passengers and cargo) and speed - see fuel cap door for recommended pressures. At higher speeds they want even higher pressure.
My guess (not a tire expert, so only a guess) is to help the tires run cooler and also to further protect against rim damage as the impulse of a pothole strike will be greater at higher speeds.
Old May 9, 2020 | 05:23 PM
2018 E63s
i reset it but in comes again sometimes after an hour sometimes after a few days?
Old May 9, 2020 | 05:27 PM
Sixpaqs's Avatar
Any reason for running at 36 psi? Are you in the US? The sticker on my fuel door says front tires at 41 psi, or higher for heavier loads. I usually run mine around 40 psi in front and 34 in rear.
Old May 9, 2020 | 05:29 PM
2018 E63s
i am located in kuwait and yes it makes the ride more smooth instead of being rough
Old May 9, 2020 | 05:34 PM
whoover's Avatar
'19 E63S sedan
You are running the front seriously underinflated and wonder why you're getting an alert?
It's your car so if prefer the ride at that pressure go for it, but the handling and dynamics of the car are compromised. It's not just about mileage. It's the way the AWD system is calibrated. As long as the TPMS detects that the front axle is not around 5 psi higher than the rear, it will complain.
Old May 9, 2020 | 06:08 PM
2018 E63s
i will lift to to 38 then , thankyou
Old May 9, 2020 | 06:17 PM
whoover's Avatar
'19 E63S sedan
That will help. Also note that your front tires are quite a bit warmer than your rears. That's another sign that the chassis is being driven unbalanced. In addition to handling, it will result in premature tire and brake wear. If you can get the temps closer, your car will thank you for it.
Old May 9, 2020 | 06:28 PM
2018 E63s
39 front (warmed) 37 rear (warmed) will be good?
Old May 9, 2020 | 07:22 PM
bobblehead's Avatar
go fast grocery getter wagon
That’s pretty well what I have (once warmed up). On a hot day, it’s around 40-41 Celsius
Old May 9, 2020 | 07:28 PM
2018 E63s
please tell me that i did not damage any components such as axle when i was driving it with low pressure tires?
Old May 9, 2020 | 07:29 PM
whoover's Avatar
'19 E63S sedan
The factory recommendation is 41 for fronts to speeds of 250 kph and 51 above that. Rears can be as low as 33.
These are cold settings. If you are talking about 39 warm that's 37 or so cold, which I would call too low. I never go lower than 39 cold.
But I was pointing out that your display shows you the tire temperatures, and they should be close after the tires are warmed up. You have 50 C in the rear and 56 C in the front. When you adjust your pressure, check out the tire temperatures for important clues on how the chassis balance is.
Old May 9, 2020 | 07:40 PM
2018 E63s
and if i adjusted the tire pressure correctly but the temperature in front is still higher? what to do next?
Old May 9, 2020 | 07:48 PM
whoover's Avatar
'19 E63S sedan
Mine always runs within a degree or so (F which is about 1/2 of a degree C). Why don't you see how they run when the tires are inflated according to spec? I suspect they will be close.
The temp sensor is very accurate. If I'm driving with the sun on one side of the car, those tires will be a degree warmer. Cool tires are happy tires (once they're warmed up).
Old May 9, 2020 | 07:53 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
. . . <snip> The temp sensor is very accurate. If I'm driving with the sun on one side of the car, those tires will be a degree warmer. Cool tires are happy tires (once they're warmed up).
Agreed. I have several different tire pressure gages, one of which is supposedly very accurate. The gauges all agree pretty well and the displayed pressure on the E63 matches very closely what I set it to with the accurate gage I have.
The tire pressure numbers on the are the pressure when the tire is cold. Whenever possible, the tire pressure should be set cold.
Old May 9, 2020 | 09:42 PM
mmmamg's Avatar
M8 convert + model Y
Sorry, there is no alert for TPMS 5 psi difference between front and rear.
I drive 43-44 both front and rear and no alerts
Old May 9, 2020 | 09:43 PM
whoover's Avatar
'19 E63S sedan
The alert is for low front. Sorry if I wasn't clear.
Old May 9, 2020 | 09:50 PM
MBS E53's Avatar
2025 GLE 53 2019 E53 2002 C230K
Will the fronts still not be slightly warmer due to the additional weight on the front axle?
Old May 9, 2020 | 10:09 PM
whoover's Avatar
'19 E63S sedan
Mine run pretty equal.
