Brakepads and Disc for w213 E63
i am searching for Brakepads and discs (front and rear) for my E63 571hp (not s) from 11/2017
I mailed some Distributor but nobody can tell which will fit for my car. From Hawk received mail that this will fit: HB731B.620 front HB808B.570 rear
can you guys agree? Can anyone tell me what is best and less dust? (exact type) porterfield, hawk, akebono?? If i search on their website, nothing will be showed.. 😫
i have silver caliper and actually original brakes.
thank you
( sry for my bad english)
thank you
asked ebc and the same.. no parts for this car
see attached picture for the correct fitment rear pad E63 non S. The manual from some sites stated the wrong one and Porterfield also didn’t realize it. I had to buy another set.
I have them on my car and they work great... a lot better than OEM for dust (but you still get it)... and probably 90% as good OEM for stopping.
but..... mine do squeak a bit at this point. When I switch to winter wheels, I am going to relube the calipers and back of the pads to see if I can take care of it. I don't really have the opportunity to drive the car hard enough and that might be a factor.
My fronts (which are Porterfield R4-S) generate significantly less dust compared to OEM, but u r right it does still cause dusting. I’m not sure about the stopping as I didn’t use any specific benchmarks prior to and after changing. But the guy that helped me change the pads was pretty sure the stopping was not as good, especially after several sustained stops. For day to day, it seems fine though.
I’ve had it for more than 1000miles and it hasn’t squeaked yet. So that’s just FYI.
disc for front i could find brembo 09.9764.23 but should to take original for rear because nothing to find another.
portefeld did clarify that they had a correct fitment on the rear that was “AP1669 R4-S”
On another note, I ordered some 2 piece slotted rotors from a company ParagonBrakes. They look similar to Girodiscs IMO. Has anyone had any experience with them? I tried to search the forum and couldn't find their name.
Here's the URL
https://paragonbrakes.com/2-piece-ro...-c63-amg-w204/
