Help-Rear squeaking noise
background info: MY18 sept edition one, 29,000km, never abuse or track, never drive in snow or rain, chassis clean every 5000km.
thanks in advance
Hummel
I asked dealer last month if the sway bar bushing is the issue but he said he does not know unless a tech checks it out on a test drive run.
thanks in advance
Hummel
dealer had to replace one of the shock absorbers it appeared to be leaking, as per the shop foreman must have been defective from the factory
Took it to the selling dealer and they did tighten it and it was OK for a while then started up again. Took it to the dealer nearer my home and they went through the whole rear anti-sway bar and checked everything and torqued to specs. Hasn't made a peep in over two years since.
dealer had to replace one of the shock absorbers it appeared to be leaking, as per the shop foreman must have been defective from the factory.
ps i got puncture and curbbed rim by hitting the pithole on the road. has made complain to the government. bad luck so far.
Very surprising the shocks needed replacement already (at just 60,000km) since I don't abuse my car at all.
I see the shocks are around $500 US each. I guess with labor and all, it would be a $1500 US warranty job
i also asked dealer to check on the sway bar bushing and whether it’s torque properly but they did not inform me of any issues from both. So, I assumed they are fine but will ask again when my new shocks come in.
a little update. since the spring is coming, the temp is back to over 5 degree during the day. the noise is completely gone but its still worth to take a proper look at the dealer after chinese new year.
dealer replaced both rear shocks and the service manager took it out to do multiple test runs over big speed bumps and said no more noises. Dealer asked me to report if the issue reoccur ASAP.
