Malfunction Drive at Max 50 mph
Got the car back yesterday, and the noise is gone while driving, however, my air compressor is pretty loud now when I press the button to raise the car. The sound it makes is like one of those electric tire compressors/inflators that you use for emergencies or for your bicycles. The noise is sustained the whole time the car is raised. It stops once I hit the raise button again to lower the car back to normal ride height.
Does your compressor make noise when you press the button to raise your car?
I don't think it ever made that noise before and I use the raise button pretty often when I go in and out of driveways.
Sorry for being so long winded...just wanted to give some background info so you guys can share your thoughts on diagnosing the problem. If yours makes noise too then I guess all is good and I just never paid attention before. I really don't want to bring the car back to the dealer a 4th time! This has been so frustrating!
Thank you in advance!
While I don't have a wagon, my 2020 sedan is very quiet when using the raise function, and it certainly does not sound like one of those electric emergency compressors. I would take it back or look for a different dealer to get this taken care of.
Spoke with my service advisor and it looks like there will be a 4th trip in for the same issue. I will be meeting with the shop foreman tomorrow morning to demonstrate the compressor noise. Watch him tell me that it's "normal".
‘if I pay attention I should say , when I lock the car I hear briefly a hissing sound and i am sure it is normal .
Absolutely a compressor noise it is not normal .
Air sys it is a closed loop sys can’t be no water inside , loose spring in the compressor, what a joke .
You see what I mean , NO PRIDE .
I can’t take it , loose spring in the compressor, they can’t even make up a credible lie .
To that end, it sounds like you regularly use the lower/raise function, is that correct? I think I have only used mine once...and now you've got me questioning how robust the system is for more regular use.
Just a quick update...
The car is back at the dealership since yesterday morning for the 4th time. I met with the shop foreman...we sat in my car and tested the raise button. Sure enough he heard the compressor noise. He explained that the compressor is mounted in the rear of the car by hangers very similar to exhaust hangers and that he personally reinstalled the compressor to MB specs along with brand new rubber bushings. Unfortunately, the noise is caused by vibration from the compressor when it is running. Told him it needs to be remedied because it was not like this before they worked on the car and I shouldn't have to accept it as it is. He will work on dampening the compressor as best as he can and if need be, he will replace the entire unit again. For what it's worth, he is genuinely a nice guy and wants to do the right thing. I feel like I'm starting to be a PITA, but all I want is for my car to go back to the way it was...noise free!
I wouldn't say I regularly use it, but I do use it...does that make sense? If I am about to go up a driveway that looks a little steep, I will use it. I might use the raise button more often that others because my license plate bracket is mounted under the front splitter so that tends to scrape on driveways.
