Swapping 18+ rear CCB to older 4-pot style?
Anyone done the swap just for the rears for the older style gold 4-pots? I would really like to do that to mine if its feasible.
I wouldn't be surprised if its not feasible, but does anyone have info on this? I can tell just from pictures that the mounting style of the caliper *appears* similar.
It would be really excellent if the rotor diameter and thickness was the same, and you could just swap the rear calipers and bleed the fluid and be done.
I can't imagine there's more than 1 rear carbon ceramic rotor spec, however looking at the photos below, they do look slightly different
Anyone have a junk <2018 4pot rear CCB caliper I can test fit?
Research I've done so far:
The W213 rear CCB caliper uses a side-mounted caliper (bolts through ears in the caliper).
Which looks similar to the R197/SLS rear CCB caliper mounting point
and the W212 CCB rear:
I've searched for info regarding AMG's decision to drop the 4 pot rear and watched a video on brakes from the AMG Youtube channel (subtitled) and have yet to get ANY explanation. There is one big consideration to keep in mind if you make the swap; what are the service and warranty ramifications? I'm betting that if you have a strong relationship with an MB Service Dept they'd probably do the work but not under warranty and God forbid if they determine other service issues were the result of the mod. I'm betting extended warranties might take issue with the mod as well.
But hey, what price for vanity...........?
At the AMG Academy at Laguna Seca they used the E63s for the braking exercises. The cars all had CCBs. They got used repeatedly for full maximum effect braking by each of the groups as we rotated through the events. I don't recall anyone noting issues with rear brake fade or lack of stopping power.
The problem I've had on some cars is too much rear brake bias during heavy braking with any kind of turning input leading to the rear of the car wanting to come around. This is pre-ESP equipped cars. Can't say that I've put the E63s into that kind of situation yet but I think the ESP would probably step in and help at that point.
Motorcycles have massive brakes up front with dual rotors and six pistons whereas the rear brake only gets a single rotor and one piston. When racing you rarely use the rear brake because there is so much weight transfer to the front that the rear wheel is barely on the ground and sometimes actually lofts off the ground during the heaviest portion of braking. This and the combination of engine braking means the rear brake is mostly just extra unsprung weight along for the ride. Dirt bikes are another story and the rear brake actually gets used a lot to help turn the bike.
The biggest use of the rear brake on the E63s is probably from engaging during traction control events to help limit rear wheel spin. If it needs any extra capability it's probably there, not for actual braking.
I've found full sets on eBay between $15k and $17 but haven't really searched around that much. I'm looking for a full set because new orders for cars spec'd with CCBs aren't getting filled because of some crazy stupid EPA issue with the brake pad material. Not sure if that means dealers can't get them here in the States and I've also heard the supply is much reduced.
It's funny how something seemingly so insignificant in appearance for most can disrupt ones psyche so much.
My car was built 2 weeks ago with CCB's, why does this issue keep coming up? By the way I agree with the rear caliper size.
https://www.ebay.com/itm/224387651224
What did the W212 parking brake look like?
EDIT: tried to research it and it appears the W212 classic foot-actuated parking brake with drum brakes inside the rotor.
I can't imagine Brembo going to the trouble to manufacture the 4 pot caliper with AND without the ebrake provision.........but then I'm not a mechanic or have spent any amount of time under either a Porsche or a Mercedes.
It's called Extrema and it's been showing up on new Ferraris (Capt Obvious). The complexity of this upgrade is the caliper mounting bracket, matching the AMG specific CCB color and having the requisite AMG decals applied.
On a similar note, I noticed that the soon to be re-released SL63 has a new rear caliper with the CCB option but I've not seen any specs or information on the new component. This may very well be the easiest change to make to the current 1 pot caliper. I learned in the search for info on the forthcoming CCBs that there is a small electric motor on the backside of the 1 pot caliper that is the e-brake system. So it's possible the new Extrema 4 pot caliper would utilize the same motor and electrical connection.
It's even possible that AMG has been listening but time will tell. I'm encouraged that there is a viable replacement for the 1 pot.........at least in appearance.
I can't tell if its a 2 piston sliding caliper, kinda looks like it, but it does at least appear larger than the E63 single piston.
subie, it looks like that new caliper is just the same 1 pot with a new ebrake on it.
I can live with the original but if I was an M owner there'd be no way, they're way worse.
