W213 E63s CAMSHAFT DEVIATED
Old Oct 7, 2021 | 10:34 PM
Senna.28's Avatar
2017 E63s AMG 2016 GLE 63s
HI all,
i have a w213 2017 Mercedes E63s,
Over the past few days I have felt there is a little knocking and jolting in the engine through the drivers seat upon cold start up.
To further limit any damage, i took it to get scanned to make sure there was nothing serious and 2 faults came up.
1 - P002477 The positioning of the EXHAUST camshaft (cylinder bank 2) deviates from the specific value. The commanded position cannot be reached
2 - P002177 The positioning of the INTAKE camshaft (cylinder bank 2) deviates from the specific value. The commanded position cannot be reached
The car has been ECU tuned to stage 1 by evolve tecnik
Just want know if anybody can shed some light on this for me as I was told by the MB tech he thinks that the reason as to why the adjustments are different from Factory spec is the tune.
Im a little confused as if so should it not be both banks not just the 1?
Thanks in advance
Old May 5, 2022 | 01:34 AM
lucky2110's Avatar
E63S, Huracan Performante Spyder
Originally Posted by Senna.28
HI all,
Thanks in advance
I have same problem as you and my car is tuned
my tuner told me it shouldn’t happen
Did you figure out the problem ?
thanks
Old Jun 13, 2022 | 06:05 PM
friberg55's Avatar
2018 E63S w213
Any luck on this? Experiencing the same thing on stock car…
Old Jun 14, 2022 | 04:43 AM
RajivK's Avatar
E63S
I have the same problem on my e63S (Stock), .
I Did run a diagnostic tool MyCarly,
Old Jun 14, 2022 | 05:01 AM
friberg55's Avatar
2018 E63S w213
i did the same with carly stock car and got the same message…
Old Sep 10, 2022 | 01:12 PM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Just looked at a stock untuned 2018 e63 same 2 codes stored in history. Ran great no issues or current light is this something to worry about ? Anyone find a solution?
Old Sep 10, 2022 | 01:24 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Why is nobody taking their 100k car to the dealer for this potentially catastrophic issue? Don’t run a car with cam issues that you can’t diagnose properly.
mb icarsoft and Icarly are not for these cars imo…very limited data.
Old Sep 10, 2022 | 01:40 PM
'15 E63S,'21 LCI M5
Yeah true. I guess this a common thing apparently. Wish I could find out the issue. Have a deposit on the car pending whatever it is. If major I'm going to walk. Limited data scanned it with an carsoft ii
Old Sep 12, 2022 | 09:09 AM
b0rderman's Avatar
E63S Wagon
Does it throw a check engine light?
Old Sep 12, 2022 | 10:29 AM
friberg55's Avatar
2018 E63S w213
no not in my case
Old Sep 12, 2022 | 10:37 AM
'15 E63S,'21 LCI M5
Same with this one. No light. Found only by scanning.
Old Aug 17, 2023 | 04:24 PM
keraj's Avatar
AMG C63S Ed1 coupe
HI all,
Thanks in advance
thanks
Guys How did your case end up?
Old Sep 9, 2023 | 10:15 PM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
im getting the same issue but just on the intake for both banks. Im currently replacing the crank sensor and all position sensors. Magnet adjusters have been replaced also. not sure if you guys have an actual cel like I am but this issue is an intermittent problem that I think its just a bad sensor issue. performance isnt affected but i do get some long 2-4 second cranking sometimes. also auto start/stop is disabled immediately.
W205 c63s 130k miles btw.
Old Dec 26, 2023 | 06:28 PM
Agustín940's Avatar
AMG E63S 2017
W213 E63s ARBOL DE LEVAS DESVIADO
Hello, were you able to solve this problem? I have my E63S and I get the two fault codes just like you do. Let's see if you can tell me something. thank you
Old Dec 26, 2023 | 08:40 PM
'15 E63S,'21 LCI M5
I didn't purchase the car after finding this code & some other red flags . I did however invest some time into this code researching.. spoke to quite a few mb techs etc. Most of them were leaning towards a camshaft gear issue . Never really came up with anything concrete stating it's definately x or y part that causes this issue .
Old Dec 27, 2023 | 04:48 AM
Agustín940's Avatar
AMG E63S 2017
Thank you very much
Old Nov 15, 2024 | 01:39 AM
W140King's Avatar
W140 S320
Reviving this thread, has anyone figured this out? Having the same issue at the moment, P002477 stored, no CEL.
Old Nov 18, 2024 | 01:27 AM
ANiMOSiTY's Avatar
2019 E63 S
You folks made me paranoid, so I checked mine.
Yup, same two codes stored:
2019 E63S with 50k miles. It regularly has 3 or 4 second cranking on cold start, but otherwise it's strong like a bull.
Old Nov 18, 2024 | 09:32 AM
PeterUbers's Avatar
4 second cold start seems too long for it to be happening regularly
Old Nov 18, 2024 | 11:13 AM
ANiMOSiTY's Avatar
2019 E63 S
Right. Clearly I have a poor sense of time. It’s about half that, as checked this morning. I can’t edit my post though.
Old Nov 20, 2024 | 08:58 AM
5soko's Avatar
AMG
Would start by using Xentry to read the codes and run the tests they have for the cams. Then doing the physical basic timing check by setting the crank to 53 degree mark (if i remember correctly), removing the 4 cams sensors on the top valve cover, looking thru the hole to make sure the cam wheel mark is half moon in the center. Easy checkups, without digging into the motor.
