E53 Coupe One Touch Rear Window Switch Change
I've had my 2023 E53 coupe since December 2022. I've come out several times only to find the rear windows open. I figured the one touch up needed to be reset. I tried numerous times with no luck. I finally had a chance to bring it back to the dealer. They told me there is no One Touch Up on the rear widows for Coupes or Convertibles. They only have One Touch Down. They didn't give me a reason other than "they never have." I find it REALLY annoying that a $95K car doesn't have both up and down One Touch.
Does anyone know if the rear switches can be replaced with a set of front switches? Neither the Service Advisor nor the Service Manager at my dealership had the answer and didn't seem overly interested in going out of their way to find out.
TIA
TIA
For the summer convenience opening/closing feature, you could also achieve the same with the door handle I believe, you pull like you open the door a notch and hold it there on the keyless go sensor it opens everything and when you remove your hand and only tap the square and hold it there, you lock everything and close everything. This might be option dependent but try it out in case your vehicle has it.
Bonus tip, you don't have to touch the square to lock the vehicle, try tapping anywhere on the outside handle (might be option dependent)
