Toyo R888R 305/35/20
Old Jun 24, 2023 | 10:54 AM
nyc_amg's Avatar
2018 E63S AMG
Hello everyone I need your help. My E63S is currently running BC Forged 20" Monoblocks 20X9.5 front and 20x10.5 in rear.
Current tires are Michelin Pilot Sport All Season 265/35/20 and 295/30/20
Unfortunately I dont know the offset of the wheels so this may be a tough ask.
I would like to run Michelin Pilot Sport 4S 265/40/20 in front AND 305/35/20 R888r in back.
Has anyone fitted this size before on even their stock wheels?
Old Jun 24, 2023 | 02:49 PM
bobblehead's Avatar
go fast grocery getter wagon
305/35/20 will fit rim width 10 - 12 inches .
20” stock rim width is 10 inches… so technically, you are ok .
but if you run 305/30/20, then it required rim width is 10.5 - 11.5 inches. So, your bc forged wheel is also ok.
as for your proposal of new setup, your speedo will read 4% lower for front; 5% lower for rear. Tire shops will likely suggest this is not ideal way to go. Not sure if this variance will cause any calibration issue with factory setup for the longer term. For me, i would not go beyond 3% variance… just my 2 cents. I see your proposal tires are track tires, I suppose you are not using that in your daily drive then
as for the unknown offsets, since you are already using these wheels, I believe there is no clearance issue, unless you tell us so
Old Jun 24, 2023 | 07:01 PM
Igooz's Avatar
car
A few years ago I installed Toyo 888r on my GT2 and it was a big mistake. The tire is horrible in anything other than perfect dry and warm to hot weather. It wears extremely fast, but the rubber turns into black (rubber) powder all over the car. Finally, it is almost as bad as Trofeo R as in they pick up every pee gravel on the road. For me, I will never touch 888R again, probably same for Toyo.
Old Jun 26, 2023 | 09:02 AM
Pilatus12's Avatar
E63s amg
Why would you put a track tire on the rear and a street tire on the front?
Or worse yet complain about track tires being bad street tires? No **** they are bad on the street.
Old Jun 26, 2023 | 10:16 AM
Keith66's Avatar
2018 AMG E43
---snipped---
A 600+ HP rear bias drive car. I'm guessing traction.
Old Jun 27, 2023 | 07:26 AM
nyc_amg's Avatar
2018 E63S AMG
my car does around 900 wheel horsepower and we do private drag events with our car club.
it is for traction, I never complained about it being bad street tires, simply asked about fitment.
I will just post my results here for those who care to run these possibly on their car.
Thanks guys.
Old Jun 27, 2023 | 11:11 AM
Keith66's Avatar
2018 AMG E43
Thanks guys.
Holy carp. Yeah, ~900 WHP is definitely a challenge to hook up properly.
Best of luck dude!
Old Jun 28, 2023 | 05:51 PM
nyc_amg's Avatar
2018 E63S AMG
I just want to report back that the tires fit, photos later
Old Jun 28, 2023 | 10:11 PM
nyc_amg's Avatar
2018 E63S AMG
Old Jun 29, 2023 | 10:03 AM
Keith66's Avatar
2018 AMG E43
Excellent, glad to see this worked out for you. They look really good too.
Being debadged, I'm sure you catch some "tough guys" totally off-guard. Nice.
Old Jun 29, 2023 | 02:12 PM
nyc_amg's Avatar
2018 E63S AMG
I have the badges just need to get them put on.
but yeh everyday people pull up and try it but I dont street race
Old Sep 15, 2025 | 09:15 PM
I.T. Guy's Avatar
2023 E63S Wagon
Did the 305/35 help and how did your like the taller tires?
I did the 305/35 on stock rims and moved to a 285/35 front to keep the dia the same. Your 265/40 is an interesting move I did not consider to do the same.
