Winter tire setup
https://www.michelinman.com/auto/tir...a4?tyreSize=20
The OEM MO spec 295’s we run are “faux” 295’s. Meaning, if you look at the tire specs, cross section and tread width, they are actually 285’s.
Also…the Michelin site has a typo somehwere. Not clear if it’s in the tire size or specs, but I suspect its the size because they didnt make a 265/30 before, so why would they suddenly change this? See below, these are 265/35 specs! I’d contact your retailer if you need this size.
Mercedes always seems to screw up a bunch of stuff with every single refresh. Heck, I'd argue they mess up as many things as they make better.
Yes, Ian, your wagon can use the added contrast.
They are pretty quiet tires to my surprise.....and Pirelli is having a rebate on these tires right now if anyone is planning on buying some new winter tires.
https://mbworld.org/forums/w213-amg/...ml#post8863722
"My dealer told me the front end should be in the 40-42 psi range and the rear would ideally be in the 35-36 psi range."
On OEM 19" winter setup and 265's square:
Cold 37-38 front warmed up 41-42
Cold 34 rear warmed up 36-37 - I may increase this to 38 it feels a bit soft on my butt-o-meter
You can do trial & error type of adjustment to your liking but should set slightly higher up front. There may be no consensus in this forum but 40-42 front and mid to high 30's rear can be your starting point
Just made first cross country trip on DWS06+ All Season Tires. 1500-miles NM-GA. Best Fuel Range to Empty 460-miles. Car fully loaded with luggage, winter gear, Air Mattress/My Pillow/Sheets, OE front wheel and Tire for spare, Tools and Real Jack, and food provisions/cooler for my Solo Wagon Train East. Outside Temps 45F-70F. Noticed steering response with these DWS06+ tires better using S+ than S. Made same trip in 2021 but with stock summer Run Flat tires GA-NM but at recommended break in speeds. MAX Q only 120mph this past weekend. Glad Premium Gasoline prices have dropped for Thanksgiving Holidays!
https://www.pca.org/sites/default/fi...r-TTW-2018.pdf
The TRUTH About Winter, All Season and Summer Tires ❄ Tested at 0C=32F, 2C=35.6F, 6C=42.8F, 10C=50F, 15C=59F:
Michelin Pilot Sport 4S vs Pilot Sport All Season 4 vs Cross Climate 2 vs X-Ice Snow:
From tire rack tests, similar stopping distances which is a good example of tire performances in different conditions:
I'm currently running OEM RTS package Pilot Spot 4S's w/ 20" staggered fit 265/35ZR20 and 295/30ZR20's on the OEM RTS rims, 20" 9.5Jx20 ET25 and 10Jx20 ET55's.
I decided to get the Pilot Alpin PA5's @ 265/40R20 MO1 BSW and 295/35R20 MO1 BSW and using the same rims (I'll worry about another set of rims next year.) I have driven on PA4's before on the E53 but going to try the PA5's on the E63s now. I've heard (subjectively) that it's an improvement
Any thoughts on this fairly straightforward strategy? I wanted to get slightly more sidewall which is why I chose that aspect ratio vs getting PA4's with the same ratios as my summers.
I'm in Southern Ontario (GTA), so not as bad for snow as further north or out west but we still get our winters.
thanks
see post #282
I have the same wheels as do many others in this forum.
https://mbworld.org/forums/w213-amg/...ml#post8875254
High of -2 on Saturday. Winter tires that are snow/ice.
No issues on iced over roads. Lots of folks going with hazards on (mostly All season tires folks) parts of highway. Even SUV were going slow.
My E63S was not wobbly or sliding anywhere. Now on acceleration it was a bit loose but nothing a throttle adjustment did not rectify.
