Difference in 2017 and 2018 E43
Welcome come to my first post!
I have checked around to find out about the difference between 2017 and 2018 E43. I only found one on Youtube. There isnt much info thus I appreciate your sharing here. I wish to know the difference so I can move towards a direction.
I am driving a GS Lexus now, a temporary car since my Alfa GTA is not longer sustainable (spare parts a pain). After driving the Lexus, I reckon I could do with a comfy luxurious feel car.
Cheers!
Cheers!
2017 model year ordering guide: https://mbworld.org/forums/attachmen...ompressed2.pdf
2018 model year ordering guide: https://mbworld.org/forums/attachmen...essed_more.pdf
So I dug further and discovered that some of the control panels have 2, 3 or 5 functions. I reckon this is part of the package selected. I always thought HUD is part of the function. It seems this function is only available to the package you choose.
Steering assist, Lane Keep Assist (both part of the DISTRONIC suite), Parktronic OFF, HUD, Airbody raise, the blank is the placeholder for the Seatbelt giver (for coupes and convertibles)
Other questions I have is, 1) MB advises the limit of sulphur content in petrol to be filled in, ie <10ppm, I would assume that's Euro5 standard. We have Euro4M which is about 50ppm. In the long run, this will damage the engine right?
2) Nothing about tyre size in the Manual. E43 originally is on 245 and 275 width. I assume like most cars, it is safe to update to 255 and 285 right?
Any sharing is appreciated.
One small one is I believe in 2017 red interior stitching was standard whereas in 2018 silver stitching was standard and red stitching was optional (I think). The red stitching is what kept me away from used 2017's, only because red stitching is not my preferred taste and I had choices so I ended up with a 2018 with silver stitching.
The following is my 2018 E43 with the P3 package.
From left to right:
Steering Assist - Lane Assist - Parktronic - HUD - Rear Window Shade - Airmatic Raise/Lower.
I went to view a few cars today and was happy with the "window shopping"
I saw a Grey Magno (2017), black and white E43. The grey has Park Assist, Airmatic+ and HUD. Black one has all 3 plus Steering and Lane. Only the white doesn't comes with HUD. None has R.window shade.
The 2018 Black has chestnut brown leather while the rest are the black w/ red stitching. I thought I like the black but upon learning its previous colour was red, it was a turnoff. The paint job isnt the best and it feels thinner than original. Hence, I am considering the grey. White is on 19" wheels with cracks under the left headlight cover.
Decision time.
Decision time.
If it was just sprayed externally, I'm sure it looks outstanding whenever you open the doors, hood or trunk, lol.
Good luck in the search!
Waiting for my PPI to be arranged.
I love my E43. For me, it's the perfect "middle ground" car and does everything I want a car to do very well.
It is the first car I've owned that is truly a Jeckel and Hyde car. In Comfort, it's quiet, comfortable and sips fuel. In Sport+ with traction control turned off (Sport Handling enabled) it's like a totally different car.
If you don't already know, Sport+ activates an electronically controlled exhaust system valve that makes the exhaust louder/deeper. It also increases the idle RPM, so you'll feel it pushing on the brakes a bit more while stopped.
Sport+ will also make it shift hard and Sport Handling (traction control off) will make it shift even harder.
If you're into pushing (abusing) the car from a start: in Sport+, traction control off, stand on the brakes hard and bring the RPM to 2800-3000 (do this quickly) and let go of the brakes while simultaneously flooring the throttle … the car will get.
Enjoy!
also I find the e43 impossible to drive in comfort. I live around a lot of steep hills and it cannot move from a stop going uphill. Just feels like it’s dying until the turbos kick in lol. And it requires full boost to get it moving. Cant remember if there’s a program fix to start with last mode.
Maybe you need to flog it a bit to wake up Comfort mode? lol
The deal is about to be off. If you can see the side doors, they have been resprayed and the sales was dishonest to say this car hasn't been in n accident. In fact, this sales person is also the owner! I like this car and this colour so I am taking a next step to bring it to a workshop for a scan to see if the accident has compromise the B-pillar and overall structure. I don't know if this is a love is blind affair but it surely sour the whole experience.
Can anyone here share if they heard or experience high engine oil consumption with this V6? Because of this experience, even with the structure and chassis safe, I have more doubts now.
My M276 uses almost zero oil between changes (every 10K miles) and Ive never had to add any oil in the time I've owned the car... a little over a year now.
If I were him, I'd want to sell this car too.
But nonetheless I sent the car for inspection. So this is the side view of the driver side which I shared earlier. Notice the 2 red spots? They are some big dings/dents. The OCD owner decided to respray the 2 doors.
On the other side which the paint job is less obvious, owner had probably brushed against the side wall thus the darker red area marks the impact area. Either side is not major damage that impact the chassis or B, C pillar.
Can I ask for the above leaks are normal for a 7yr old car? What need to be done is to replace the valve cover seal, auto gear box seal and new oil fitler right?
I hope it is nothing major as long as you replace the seals before it gets worse.
Valve cover leak oil is common though. Need to remove it and re-silicone it, engine doesn't have to be removed from vehicle so it isn't that bad.
1. Is the rear main seal is easily replace and asssessible, together with the valve cover?
2. I know one cant really tell if the engine is consuming oil at a high rate without driving it for a while, But what are the tell tale signs usually, besides white smoke from exhaust?
Appreciate some advice.
2. I know one cant really tell if the engine is consuming oil at a high rate without driving it for a while, But what are the tell tale signs usually?
2. If engine constantly overheats
