Do I need special shoes to open tailgate???
Subscribe
Dec 18, 2024 | 08:03 PM
Excellent! I'm guessing with the wagons and SUVs the distance matters even more since the gate swings open right into you.
Reply 1
Dec 23, 2024 | 01:05 PM
@superswiss My VMI log show P17 as "KEYLESS-GO PACKAGE", but what's in a name? P17 includes keyless door locking/unlocking, push button start and trunk/boot auto open/close (on supported models).
It appears 871 SENSORS FOR TRUNK LID OPENING/CLOSING is configured with P17 for models with the boot kick feature. The fact there is a separate option code suggests the existence of P17 isn't definitive on boot kick feature. Config logic is probably "if P17 selected AND boot kick feature is on model list AND is on country list, configure 871). Even the E63s manual is written with 871 potentially being separate from P17.
Aussie_E350_Wag, if your doors unlock when you grab the door handle, you at least have P17.
It may be useful to have an E350 owner confirm the boot feature was included on that model in at least their country.
You do have your key in your pocket, yes?
Is the rear diffuser nice and clean?
Found this post, same topic.
Reply 0
Dec 23, 2024 | 03:52 PM
Rear defuser? This is not the same part....I can go crawl under and get a photo. I can say with 100% certaintly that this feature does not work "up north" when cars are covered in snow or salt.
Also....you know Ben?
Reply 0
Dec 23, 2024 | 06:36 PM
@OldManAndHisCar I'm afraid I am guilty of loose talk. I always assumed there was some sensor underneath mounted through the rear diffuser. Crawling under there, I saw nothing but smooth black plastic. Doing a little sleuthing, apparently the two rear facing sensors (changed from "camera".... sigh... I keep digging my hole deeper) in the bumper detect the necessary motion. Too bad MBWorld doesn't let you go in and fix mistakes... or at least let us click a box to tell reader to look down lower for a correction.
Now I'm curious what the 871 option is if the rear bumper sensors (not camera) sense the kicking motion.
Probably someone else needs to explain since I've totally trashed the explanation. Must be my age showing.
Reply 0
Dec 23, 2024 | 07:09 PM
Quote: @OldManAndHisCar I'm afraid I am guilty of loose talk. I always assumed there was some sensor underneath mounted through the rear diffuser. Crawling under there, I saw nothing but smooth black plastic. Doing a little sleuthing, apparently the two rear facing cameras in the bumper detect the necessary motion. Too bad MBWorld doesn't let you go in and fix mistakes... or at least let us click a box to tell reader to look down lower for a correction.
Now I'm curious what the 871 option is if the rear bumper cameras indeed double as sensors.
Two rear facing cameras in the bumper? What are those?
Reply 0
Dec 23, 2024 | 09:26 PM
W213 rear bumper
Reply 0
Dec 23, 2024 | 10:05 PM
  #32
Quote: W213 rear bumper
Those are distance sensors.
Reply 1
Dec 24, 2024 | 12:56 AM
  #33
Quote: Those are distance sensors.
Yes, there are no cameras in the rear bumper!
Reply 1
Explore
Dec 24, 2024 | 03:02 AM
  #34
Quote: @superswiss My VMI log show P17 as "KEYLESS-GO PACKAGE", but what's in a name? P17 includes keyless door locking/unlocking, push button start and trunk/boot auto open/close (on supported models).
I have the trunk ninja-kick option to open/close trunk lid.
It does work reliably once CAN-B is sanitized
else you need to danse before car will pay attention to your request such that you learn to use keyfob button.
Reply 1
Dec 24, 2024 | 07:05 AM
  #35
Quote: Yes, there are no cameras in the rear bumper!
My mistake, I see now . You were posting in response to the other person to show them. I thought you were questioning what they were because of the question mark in your picture.
Reply 0
Dec 24, 2024 | 12:13 PM
  #36
Never had any issues with mine - except when washing and detailing my car around the trunk area. Have been hit in the head several times.
Reply 0
Dec 24, 2024 | 12:58 PM
  #37
Quote: Never had any issues with mine - except when washing and detailing my car around the trunk area. Have been hit in the head several times.
In that case, recommend disabling the smart key and keyless go by doubling pressing the lock button until you see two short flashes and then followed by one long, enable it anytime by pressing any button when you are done the wash.
Reply 2
Dec 24, 2024 | 01:19 PM
  #38
Quote: I learned I had it as I was under the car looking at something and freaking out the rear opened and hit the back of my garage door......
I got surpised when I was working on my rear brakes. I was under the rear of the car with the car up on jackstands. I had the key in my pocket and somehow activated the trunk open feature. My tools were laid out on a towel on top of the trunk; they rolled off and made all kinds of noise. Since I was under the car and couldn't see the trunk, I thought the car was falling on me for a second. Then realized what was happening. Still don't know what "magic motion" I used to activate the trunk
Reply 0
Dec 24, 2024 | 01:52 PM
  #39
Quote: In that case, recommend disabling the smart key and keyless go by doubling pressing the lock button until you see two short flashes and then followed by one long, enable it anytime by pressing any button when you are done the wash.
THIS IS PRICELESS - never knew this, and too lazy to seek this info, thank you!
Reply 0
Dec 24, 2024 | 02:06 PM
  #40
The 3rd press is new to me. What's the difference between doubling pressing the lock (which disables keyless go) and then the 3rd long press?
Reply 0
Dec 24, 2024 | 02:14 PM
  #41
Quote: THIS IS PRICELESS - never knew this, and too lazy to seek this info, thank you!
You're welcome, happy to help. Alternatively you could lock the trunk from the glovebox instead and it won't open no matter what even if you have the key on you.
Reply 1
Dec 24, 2024 | 02:15 PM
  #42
Quote: The 3rd press is new to me. What's the difference between doubling pressing the lock (which disables keyless go) and then the 3rd long press?
Sorry for the confusion, not a 3rd press but the light stays on for longer to confirm the keyless go is disabled.
Reply 0
Dec 24, 2024 | 04:02 PM
  #43
Quote: Sorry for the confusion, not a 3rd press but the light stays on for longer to confirm the keyless go is disabled.
Gotcha! Thanks for clarifying.
Reply 0
Dec 24, 2024 | 06:02 PM
  #44
Quote: Gotcha! Thanks for clarifying.
You're welcome, happy holidays : )
Reply 0
Dec 24, 2024 | 07:35 PM
  #45
So how does the kicking motion actually work? I mistakenly used the word "camera" when I meant the little round sensors that @6G Schnell posted. (camera is the device that is hiding above the license plate). But I'm still unclear what devices sense the kicking motion. Also not clear what the 871 SENSORS FOR TRUNK LID OPENING/CLOSING actually is. Additional hardware? Software/configuration only?
Reply 0
Dec 24, 2024 | 07:42 PM
  #46
Quote: So how does the kicking motion actually work? I mistakenly used the word "camera" when I meant the little round sensors that @6G Schnell posted. (camera is the device that is hiding above the license plate). But I'm still unclear what devices senses the kicking motion. Also not clear what the 871 SENSORS FOR TRUNK LID OPENING/CLOSING actually is. Additional hardware? Software/configuration only?
Oh you meant the sensors, I see, that makes sense. As for how it works it senses an obstacle (in this case, your foot) as part 1 and when you remove it then it activates the tailgate as part 2.
Reply 0
Dec 30, 2024 | 01:07 PM
  #47
Re-reading this thread, I'm also curious why the trunk opens if you're UNDER that car (as @carlosinseattle related). If you're under the car, those rear bumper sensors shouldn't see you at all. For my part, I've been sitting on the tailgate with the back open (classic tailgating) and the damn thing came down on me. I found out there's no auto-reverse if it hits an obstacle, like garage door openers have. At least, my reaching up to stop it from chopping me in half didn't stop it. We just got into an arm wrestling match until I managed to hit the manual open/close button on the tailgate (wagon).
Reply 0
Dec 30, 2024 | 01:52 PM
  #48
Quote: I find the reverse kick method working better.
I tried the reverse kick since you posted about it and have found it to be quite reliable on my car. Thanks!
Reply 1
Dec 30, 2024 | 03:55 PM
  #49
Quote: Re-reading this thread, I'm also curious why the trunk opens if you're UNDER that car (as @carlosinseattle related). If you're under the car, those rear bumper sensors shouldn't see you at all. For my part, I've been sitting on the tailgate with the back open (classic tailgating) and the damn thing came down on me. I found out there's no auto-reverse if it hits an obstacle, like garage door openers have. At least, my reaching up to stop it from chopping me in half didn't stop it. We just got into an arm wrestling match until I managed to hit the manual open/close button on the tailgate (wagon).
Although there is no auto reverse but if it hits an obstacle it plays a chime and stops where it hit, it won't keep trying to close.
Reply 0
Dec 30, 2024 | 03:56 PM
  #50
Quote: I tried the reverse kick since you posted about it and have found it to be quite reliable on my car. Thanks!
That is great, I am happy to help : ) Sorry for the confusion before that, glad the clarification helped!
Reply 0
