Recommended storages for dashcam?
Old Feb 9, 2025 | 06:13 PM
exturnul's Avatar
2021 CLS 53 AMG C257, 2023 W223 S580, 2021 X167 GLS450, 2022 V167 GLE350
What storage medium / slot do you guys use for your dashcam options? I have tried with a SanDisk dual-port in the middle armrest center console but all of my files keep corrupting, cannot recover and when viewed through the MBUX Media option, i can see some frames but then i will get stretching of frames and then video becomes unplayable. I use the loop recording feature that gets 1 minute snips.
Cannot recover from computer, phone, etc. Files are unviewable and unusable
I don't know if this is an MBUX issue and there is a software update or something
Old Feb 9, 2025 | 07:52 PM
W205C43PFL's Avatar
Use a dashcam rated sd card such as samsung endurance and class 3 but not a must.
I guess the file format formatted also matters.
Old Feb 10, 2025 | 12:43 AM
exturnul's Avatar
I switched to a Samsung T7 1TB SSD today and was able to view the videos in the dashcam after a delay of about 5 minutes of buffering, still unviewable on pc
Old Feb 10, 2025 | 01:24 AM
exturnul's Avatar
I got one frame! YAYY!!!
Old Feb 10, 2025 | 02:00 AM
exturnul's Avatar
I think my dashcam's encoder has something horrifically off with it, gonna take this back to the dealer and hopefully get it sorted out under warranty
Old Feb 10, 2025 | 07:34 AM
W205C43PFL's Avatar
Hmmm, hopefully it works out.
Old Feb 10, 2025 | 07:40 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
MBUX was using way too much system memory for disk caching on my EQE SUV. About half full and dashcam would start to get real slow and it was 50/50 whether it would get corrupted when full and it tried to "loop". I shrunk my 1 TB partition down to 128 GB and that solved all my problems.
Old Feb 10, 2025 | 08:42 AM
W205C43PFL's Avatar
Originally Posted by GreasedFolgore
MBUX was using way too much system memory for disk caching on my EQE SUV. About half full and dashcam would start to get real slow and it was 50/50 whether it would get corrupted when full and it tried to "loop". I shrunk my 1 TB partition down to 128 MB and that solved all my problems.
nice hopefully that is the solution for OP.
Old Feb 10, 2025 | 12:36 PM
exturnul's Avatar
I already tried with a small sandisk flash at 128gb but that just also corrupted. Could you link the drive you use?
Old Feb 10, 2025 | 12:51 PM
I used an actual NVMe SSD in a USB-C enclosure and it still wasn't fast enough.
I see I had it formatted 64 GB though. I guess I was thinking about trying 128.
Old Sep 23, 2025 | 11:28 AM
BuckeyeBenz's Avatar
2021 Graphite Grey E63S AMG Wagon
I think I have the dashcam option, I bought my 2021 E63 Wagon used back in July. The camera comes on when I am at a traffic light and randomly sometime when I am parked in view of a street with cars going by. I can not find where to put the SD card, where to view anything on the MBUX, or anything in the owners manual.
Can somone tell me where to put the SD card, if I have the option to do so, and where to access in the MBUX system?
Thank you!
Dan
Old Sep 23, 2025 | 11:33 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
There is no SD card slot. Instead, use a USB C thumb drive. I use a 256GB or 512GB Samsung one, no problems. There is a dashcam app in the applications section to turn on automatic recording.
Amazon Amazon
Old Sep 24, 2025 | 10:18 AM
I guess I don't have the dashcam option. I plugged in a SD to USB-C adapter into the center console USB-C thinking the Dashcam app would come up in my Mercedes Apps folder but it did not. I didn't see a place to download the app. I guess my car has the actual camera and it does work at traffic lights but does not have the dashcam function. Does anyone know if there is a way to turn on or buy the dashcam function?
Thank you.
Dan
Old Sep 24, 2025 | 07:07 PM
OBP's Avatar
OBP
E63 S AMG, CLS550 4matic, C63 Ed 507, Volvo XC90 T8s
Thank you.
Dan
When you scroll through the center screen and get to the Apps menu, do you see "Dashcam" as one of the items in Apps ? If so you have the feature from the factory. If not then you do not. The camera itself is not the issue - most of us will have the camera you describe. The dashcam software was a specific factory option around $150 to $200 IIRC and that needs to be loaded at the factory. If not then you are looking for some kind of coding solution from an online source, some of whom advertise their work on this forum.
BTW prior to a free software update in 2024 for my 2021 E63 sedan, my dashcam app would be intermittent. So that is one more wrinkle that you may want to figure out with the dealer ....
Old Sep 29, 2025 | 11:13 AM
I do not have the Dashcam app. Thanks for the heads up on the app being intermittent. I'll have them check it next time I bring it to the dealership.
