Tech: SAM Modules query
What do you want to achieve?
It can read data from every of the 45+ modules.
The network configuration is all diagrammed in WIS format with all the distinct nodes interactions.
It's high-tech but hardly reliable. Simple chassis "Reboot" help sanitize legendary battery drains under 5mn.
I can read Canbus signals with an O-scope (Lecroy HRO66zi) that has CANbus/Lin/MOST debugging or a canbus reader. Just wanted to know some tech background on it is all.
How do you use its output ?
With your hability to interact with nodes you can do signal troubleshooting.
I think MB has an issue with multiple voltage threshold levels on different branches of the same network. MB CAN is forced to be voltage sensitive where it should not.
