2018 E63s blown engine
Not sure if anyone else has experienced this and what the outcome was? Also heard that engine is on backorder with no ETA??
were you running rich that the spark plug tip burned and broke off?
are you modded? Tuned?
refurb engine?
are you covering the cost of all this?
to me if plug is broken, then it’s parts failure and dealer needs to investigate and discuss with you. If they just tell you need a new engine, then sounds like they are not taking any liability/responsibility at all. There should be a protocol for dealer to follow especially the service was done by them
So, dealer parts failure is what your dealer should start with. They provided the plug, they are still somewhat responsible for it … imo.
As to engine damage, yes broken off spark plugs getting into the combustion chamber will do a number. Dealerships won't rebuild an engine, but if you take it to an engine builder, they may be able to sleeve the damaged cylinder. The trick is the NANOSLIDE cylinder wall coating process that AMG uses. The sleeved cylinder will have to be coated as well. That's something to keep in mind if you are left footing the bill. As said, though, there should be warranty on the spark plugs and the workmanship.
while the engine is out have the tech
- Install the latest version OVS and RMS (on your own dime unless you have an extended warranty that would cover this in the future)
- This is presuming the dealer covers parts and labor for the engine replacement
Blaming the parts is going to be a stretch….
I had a wall full of those type of plugs up in my old shop as a reminder. Usually happens on the ragged edge in search for more power in racing applications. Ceramic/electrode parts of the plug will destroy that cylinder/valvetrain in less than a second. Very little margin of error on these engines. High compression coupled with forced induction is very efficient, but if something is “off spec”., these engines, while making a ton of power, can be quite unforgiving. Always run best gas you can get!
How MB handles this type of failure will be an entirely different matter
Good Luck and sorry this happened to you!
We all trust that the gas we put in our cars is to spec. But what happens in the gas stations storage tanks can also impact what’s in our cars tank. Or even unscrupulous owners switching gas grades is not unheard of….
Many if not most of the failures posted on this (and other non MB) forums is detonation/pre ignition related. The common thread is over 10:1 compression and/or turbocharged engines and pump gas.
When everything is running in spec. Not a problem.
Once a fuel or ignition issue crops up, that’s when the failures start to happen. It would be interesting to see what codes popped up in XENTRY on your car….
Knock sensors are great but engine needs to knock first in order for them to adjust timing.
None of this is any consolation, and I definitely would pursue the fact they changed the plugs and repair is under warranty. It’s leverage even though it’s probably just a coincidence. Can’t tell you over the years how many times I’ve done a simple repair such as an oil change only to have the car come back the next day needing a water pump
Total coincidence, but poor owner doesn’t realize it….Good Luck
It sounds like something that happened to me.
I was at a light about to turn right and the car started sputtering and not being able to rev past 3000 rpm. Had to hobble the car back home. Check engine light came on.
Next day, took it to the dealer, still had Check engine light but the car ran fine. Tech saw faults on 3 cylinders AND low fuel pressure but tank was full. So they reset light AND ALL learned adaptations and recommended "italian" tune up (technically they said it is an AMG so to drive it like an AMG).so I did..has not happened again.
what i can tell you, it felt AND sounded like the car went from 8 to 4 cylinders and "forgot" to come out of that mode.
Any aftermarket warranty?
