tires for W210
E320
tires for W210
Hi, all,
I am thinking of buying some wheels, which come with tires on them.
However, the size are not as recommanded on tirerack's website.
They are 225/40/18 and 255/35/18, and I know I should use 235/40/18 and 265/35/18.
But, will it be OK if I use these wrong size tires?
Thanks,
Ben
Thanks,
Ben
TR Moderator & Tire God
depends on the weather
those tires are shorter than recommended and do not have the proper laod capacity ..... they are close enough not to cause any problems in the short term if you run atleast 36psi in them but, when the wear out get the correct size
Originally Posted by Ben'z
Hi, all,
Thanks,
Ben
Thanks,
Ben
E320
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Originally Posted by E55AMG99
Better choice would be 245 in front and 275 out back.
Originally Posted by E55 KEV
Not a better choice. Those sizes are only recommeneded for E55's because their fender lips have been rolled by AMG. The W210 front rim is 18x8 et31. Using an 18x8 et35 will rub inside using certain tires and that offset only pushes the rim inward by 4mm.
I guess I was lucky when I put a set of E55 tires and wheels on my E430!
1 Post
2018 AMG E63s
I change my wheels and tyres the day after i took delivery of my E320 8 years ago
I have been running AMG wheels (same as the E55) 235/40/18 front and 265/35/18 rear ever since without too much problems
Just have to avoid Sydney's pot holes after it rains
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
Front - 18x8 et31 - 245/40/18
Rear - 18x9 et35 - 275/35/18
