19X9 19X10 for W208
Kleemann CLK 43K
19X9 19X10 for W208
I just bought a set of used wheel but found out later that they are 19X9 and 19X10. Will they fit my CLK430? If so, what tire size should I put on them? Should I return them to the seller?
Thanks in advance.
Thanks in advance.
Can you be any less specific?
So, you just purchased a set of rims without knowing if they would fit? A 9" front may be too wide. What did they come off? Rims from a Mercedes S, SL, CL and current E-Class usually don't fit. Be prepare to return them.
Kleemann CLK 43K
Ya, I should be more specific on the questions.
I know 235 front and 265 rear are the maximum tire sizes for most W208. However, 19X9 and 19X10 are a bit too wide for these sizes. I know they can fit but the rims will have little to no protection from the tires and have higher chance of getting curb damages. It might also look bad too. I heard that 245/275 may work with rolled fenders and some experiment on different offsets.
I want to get some opinions on what tire sizes I should get with these wheels.
235/265
245/265
235/275
245/275
I will be using Toyo T1-R.
235/265
245/265
235/275
245/275
Mercedes-Benz
235/265
245/265
235/275
245/275
235/265
245/265
235/275
245/275
We still don't know the offsets of these wheels? The offsets of these used rims may make this whole thing moot! Also, wheter or not the the used set uses 12 or 14mm ball or cone seats. Lost of info is needed.
Mercedes-Benz
Kleemann CLK 43K
Perfect drop, aintMe. What is the setup of your suspension? I have the same wheels too.
The offsets are 35mm for the front and 45mm for the rear. The rear comes with a 18mm spacer. Scorchie mentioned that ET30 for the front works for his 245 tires. Other then his setup I couldn't find much offset information.
Mercedes-Benz
Your offsets are inline with my brother's set-up 35/45 w/ rear spacers. However, he ran an 8" front wheel. You can see how close it is with that. I *think* your 9" front might be a no go.
Mercedes-Benz
aintMe, you are right. I tried 235 with 19X9 ET35 and that did not work. I am returning the wheels. Thanks for your help.
