need advice. upgrade to 19" on w210 e55
You should be able to use a 285/30/19 on the back, plenty of room to push the tire/wheel inward in back.
Also check the lug bolt size on the Ebay rims. W210 use 12x1.5. If 14x1.5 like from an S-Class it won't work.
Mike
We have done many E class Mercedes with 8.5 et35 and have not had any problems. I am pretty sure that a couple of those were E55's. Obviously there are many models and diferences between years so it is always hard for rim companies to keep 100% up to date on every fittment. This is what we try to do by using our retail experience to pull from. Since I personally can not recall a problem we have encountered, I need to find out more. I hope you can help.
Here is a link to some photos of w210 cars with 19x8.5 et35 wheels installed. They are running 245/35-19 and have plenty of room. One is a E430 and the other I am not sure. I have to pull the pictures at work and see if I have a rear shot.
https://mbworld.org/forums/showthrea...&highlight=nzo
As you can see from the side shots of the black e430, any lower of an offset up front would start to push the wheel out from under the fender
Mike
Tire Rack always recommends a 235/40/18. Why does Tirerack.com 'not' recommend a 245/40/18 tire for 18" but recommed a 245/35/19 for same rim width and offset:
18x8.5 et35 - 245/40/18 not recommended for W210 E320
19x8.5 et35 - 245/35/19 is recommended for W210 E320
How could the one fit and the other not according to Tire Rack?
Those are some good questions. We have run 235/40-18 and 235/35-19 on all c class models with 8.5 and et35, no problems. We have run the same wheels on all E class with 245/40-18 and 245/35-19 no problem. This is why your statement puzzled me. I do not understand why Tirerack can recomend one size and not the other. They are effectively the same. Same width, same offset, and same overall diameter. In fact we have noticed more room for forgiveness on the E class than the C class. This is why I asked if there is a suspension difference on the E55 versus the regular E class. To me it looks the same.
Our chrome wheel, the Halo II, is a 18x8 by the way with a offset of 35mm. We have run this as well with 245/40-18 with out incident. Are you sure the wheels you received were not mismarked?
Thanks for the info too.
Mike
Mike
