Tire size selection HELP!
Old Jun 29, 2006 | 07:08 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I justt bought some new wheels and I need to know what is the optimal tire size for a 1998 w210 E320 lowered with the E55 suspension.
Currently I have E430 (sport) wheels on there which are 17x8 et 37mm all around with 235/45/17 tires
The E55 wheels are 18x8 et31 front and 18x9 et35 rear with 245/40/18 front and 275/35/18 rear.
The new wheels I have are 18x8 et32 front and 18x9 et32 rear.
My question is: What size tires do you think would work best? I'm guessing 235/40/18 front and 265/35/18 rear.
The fronts are 1mm closer than the E55 wheels into the body so a 235 width I believe is best. With the rears, they are 3mm further out, so a 265 width is best so it doesnt rub on the fender. Also with this combo, the actual circumference will be just minimally off so it won't have any effect on traction control.
Opinions?
Old Jul 5, 2006 | 10:23 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
I agree with your assessment of the 235/265 combo
Old Jul 5, 2006 | 03:33 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Hey Luke, for non AMG W210's TireRack will not recommend a 245/40/18 up front but recommends a 245/35/19 on a rim with same width and offset say 8.5 et35? If a 245 will work on a 19" it should work on a 18" with the same rim width and offset?
Old Jul 5, 2006 | 03:41 PM
Dan Wang's Avatar
Thanks Luke.
Old Jul 19, 2006 | 06:30 PM
Dan Wang's Avatar
Luke, I just picked up a brand new pair of Bridgestone SO-3 265 35 18 on ebay for $150. Why doesnt Tirerack sell this tire in this size?
Old Jul 20, 2006 | 12:57 PM
we did but, it has been discontinued and we can't get any more
conservative website recommendations ... I would run 245's if it was my car with 275's out back .... but, with 265's you would need to run 235's .... and 275's will require a fender roll
Old Oct 5, 2006 | 02:43 PM
osdesierto's Avatar
so with 18 x 8 31 offset with 245/40/18 fronts and 18 x 9 35 offset with 275/35/18 rears would be ok on 2002 E320 then?
thanks luke!
Old Oct 5, 2006 | 03:20 PM
ultra conservative website applications ....
Old Oct 5, 2006 | 05:21 PM
E55 KEV's Avatar
Veteran: Air Force
thanks luke!
sounds good, but check for rubbing on fender just incase - since the fender lip is rolled on E55 using those sizes..
Old Oct 5, 2006 | 06:21 PM
osdesierto's Avatar
Nice a snug fit.... :-) I will take some pictures to show the difference. the car is sitting 1/2 hgiher now with 18' but loveing it!
