Just ran through some Pirellis in 8000 miles, Luke- I have questions
Old Jan 3, 2002 | 05:00 PM
Newbie's Avatar
I've got a 2000 CLK430 Coupe, and this is the 2nd set of tires I've gone through in 20K miles. My first were AVS Sports, and these are Pirelli P-Zero Direczionales (sp) in front and Assimmetricos in the back.
I've got a lot of negative camber, and I was wondering if it's possible to correct that with camber plates? The wear on the inside of the tires is quite disconcerting. The inner edge is always completely bald way before the rest of the tire is used, and I've been told it's normal because of the way the car is lowered and the size of the wheels- any suggestions?
The wheels are 18x8.5" Front, 18x9.5" rear, and the car sits on H+R Sport springs. I'm using stock shocks right now, and I'm thinking about switching to Konis.
Old Jan 3, 2002 | 08:40 PM
Randy B's Avatar
**SOLD***2003 E500
inside wear.
With your lowering springs, the suspension may not be able to adjusted to compensate for it. This is very typical of lowering springs that effect the ride height. Remember your car was engineered and deisigned for a taller spring, and so were the camber and caster adjustments. Remember your aftermarket springs were designed for racing and endurance runs. People who race and do endurance runs only use those tires for so long and then replace them. If you expected to get good tire wear (plus 10,000 miles) and have these springs you were incorrect on your expectation. Your handling went up, and your tire wear went down. Next time take a look at your car when it is parked, and you should be able to see the inside of the suspension flared out toward the outside. That is due to your aftermarket springs. Did you try any of these tires without the springs to see if you get different tire wear????? I would defintely try that with your next set of tires, and see how much cornering you really lose in the real world of driving.
Old Jan 3, 2002 | 09:29 PM
Mach430's Avatar
Camber plates should help (if available). Also, get your tires rotated side to side (not front to back since your staggered). If your tires are directional, make sure they still face the right way when they are done.
Old Jan 3, 2002 | 10:02 PM
Newbie's Avatar
Thanks Randy, I was aware of what I was doing in order to achieve better looks and handling- just wanted to know if CC plates were available for my application.
Mach 430- the tires I have right now aren't supposed to be rotated, even side to side in the front. There's a different tire for every corner.
Old Jan 3, 2002 | 10:36 PM
Mach430's Avatar
I'd say get different tires next time. Even without the camber, it's best to rotate them. I'll check on camber plates for you.
Old Jan 3, 2002 | 10:45 PM
Mach430's Avatar
Couldn't find any Camber plates, sorry. What did you use to lower your car? Spring pads? Cut coils?
Old Jan 3, 2002 | 10:46 PM
Newbie's Avatar
Like I said, I used H+R Sport springs to lower the car- that's it. Stock pads, uncut springs.
Here's a picture in case anyone wants to see how good it looks .
Old Jan 3, 2002 | 11:56 PM
Mach430's Avatar
I have the same springs + koni shocks, and while I have negative camber, it is definitely not enough to warrant you running through tires every 8,000 miles. I would expect 12,000 at the minimum. Did you get your alignment done?
Old Jan 4, 2002 | 12:47 AM
Vic55's Avatar
Administrator
According to your post you have PZero Yellow's in the rear and those are super soft. They carry one of the lowest treadwear ratings for a high performance tire at 140. I had them on my GS400 (275x30x20) and they lasted about 15k miles and my car was dropped with Eibach springs. I have the PZero Rosso's which carry a treadwear rating of 240 so they will last longer but I have not had that luxury. I have a H&R drop on my E55 and the tires only lasted about 10k miles. The tirewear though is even through the middle to the outside so my alignment is in check- it must be the torque from the E55 Next on my list will be Bridgestone S03's.
Old Jan 4, 2002 | 07:54 AM
Randy B's Avatar
**SOLD***2003 E500
Red face Treadwear rating
Vic55, one note on treadwear ratings. The number derived for this rating is completly arbitrary. Each manufacturer rates their own tires based upon one of their models that they consider to be average wear. That is the zero model, and anything that exceeds or not is rated based on that tire. This zero model is different for all manufacturers, and therefore the compounds and plys used for the zero model vary. So beware what a treadwear rating means within a companies mind, and findout from the manufacturer what the model of tire was used for the zero model. This was a complete eye opener for me.
Old Jan 4, 2002 | 11:10 AM
Vic55's Avatar
Administrator
Re: Treadwear rating
I agree 100% with you and since the tires I had (Rosso's) and the tires that Newbie had are both Pirellis and part of the Zero family wouldnt it be safe to assume that these tires fall under the same treadwear rating measurement tests that Pirelli may administer?
Old Jan 4, 2002 | 02:41 PM
Randy B's Avatar
**SOLD***2003 E500
Poor choice of words on my part,
Where the Zero model was used in my previous post, this should have been control model. If the control model was a slick sticky high wearing unit, the number you have on all other Pirelli's reflects how much longer it should wear in regards to the control model. Ie: TWR of 240, means 240 more times than the control model used by the manufacturer. If the tire manufacturer used a hard long lasting control model tire, than your TWR shoudl be less for perhaps the same class of tire you are using. Really gimicky, that thhere is not a standard for the industry for TWR's. At least they finally started putting birth dates on the tires, thanks to the old Firestone 727's.
Old Jan 4, 2002 | 04:02 PM
Newbie's Avatar
All I know is that my AVS Sports lasted 11,000 miles. Come to think of it, though- I got new tires because of an accident, so the fronts only wound up lasting about 9K miles. Damn I go through tires fast. The S03s have a 300 treadwear rating, which is why I bought them. I wasn't aware until now that the number is arbitrary, but I'm sure they'll last longer than the AVSs and the Pirellis.
After 8K, my rears (the assimetricos) are fine. I'll burn through them and get some S03s for the back within the next month or two.
Old Jan 4, 2002 | 04:28 PM
Mach430's Avatar
If you need help burning through your rears, I suggest you look left towards my picture. Rear tires= 0 miles
Old Jan 4, 2002 | 06:01 PM
Newbie's Avatar
Yep, I'll be doing a lot of burnouts, especially at the track. The 1/4 mi. strip at the Cali. Speedway is opening for the season next weekend, and I've got a lot of people to race .
Old Jan 4, 2002 | 07:02 PM
JamE55's Avatar
Out Of Control!
Newbie check you PM!
Old Jan 7, 2002 | 08:26 PM
Newbie's Avatar
BUMP
Old Jan 8, 2002 | 05:50 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
sounds like either a heavy right foot or driver error ..... just kidding
The tire grading that goes on when it comes to tread wear is very ambiguous. All manufacturers do perform the same test but are allowed to interpret the results any way they want which in some cases leads to high wear numbers that are at the best erroneous. However on the other hand tires from one manufacturer such as Pirelli do merit some consideration the P-Zero system tires do not last as long as the P-Zero Rosso tires.
Luke
Old Jan 8, 2002 | 06:59 PM
Newbie's Avatar
Originally posted by Luke@tirerack
sounds like a heavy right foot
Damn right, that's what everyone tells me. I drive the wheels off my CLK430 every day .
