Question about wheel & tire fitment for C350 (W204 chassis)
C350 & ML350 soon!
Newbie here to MB. Will be purchasing the C350 Sport Sedan w/ 18" AMG factory option. I understand that the wheels are a staggered fitment. I'm looking to replace the wheels with an 18" fitment that is not staggered.
A question (for Luke @ Tirerack):
1) Will I run into any issues with running a regular fitment vs a staggered one? The reason I want a regular fitment is I'd like the ability to be able to rotate my tires to extend tire life.
Thanks in advance for your help!
Former Vendor of MBWorld
Van, with no windows.
Mercedes made staggered wheels for the C350 for a reason, we highly recommend you keeping the staggered setup, due to the fact that it can affect the driving ability and braking.
C350 & ML350 soon!
Thanks Wheel Power, your response is much appreciated! I'll keep the staggered setup, then.
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Actually you can put on a non-staggered set. I posted a PDF link in the W204 forum showing MB approved wheel fitment. Have a look at it.
Now, will you be running into issues; maybe. Depends on your driving style. Will you notice those in everyday driving; highly doubtful. HTH
TR Moderator & Tire God
depends on the weather
While, you can safely and easily use a non-staggered set up on your car there are several reasons that the staggered set up was used from the factory. The two most obvious are:
#1.) with a wider back tire a car has less of a tendency to have throttle induced oversteer.
#2.) the wider rear tire creates understeer which is deemed to be needed for safety.
with that said the use of non-staggered wheels/tires is perfectly acceptable providing you understand the change in the vehicles handling dynamics the cahnge created. I actually recommend non-staggered setups for winter use.
C350 & ML350 soon!
Would this be also true for BMW? Reason I ask is that the MB dealer is getting difficult to deal with and the gf & I are looking at BMW now. Thanks again, Luke, I did get your voicemail btw.
C350 & ML350 soon!
