Flaring the fenders
Old Feb 7, 2003 | 02:09 PM
Swank500's Avatar
1984 Mercedes 500 SEL
Question Flaring the fenders
Can anyone explain to me... How to flare the fenders on a vehicle?
Old Feb 7, 2003 | 07:51 PM
Lynn's Avatar
Step 1. Find a outstanding body shop.
Step 2. Hand them a large wad of money.
This is not a d-i-y project. It involves cutting the inner and outer fenders to increase the radius of the wheel opening. Panels must be fabicated and welded in place to connect the inner and outer fenders to retain the structural rigidity of the car. The flare is fabricated (or purchased) and attached to the fender. These are welded into position and the welds are gound with an air grinder. Body filler is applied and sanded. Usually several coats are used to fill imperfections and hide the welds. The fender well is is prepped and painted. The fender is prepped and painted. Now do this three more times to finish to car. You may as well have the entire car painted while you are at it. This is oversimplified and will vary somewhat from car to car.
Or you can find some rubber fender flares and pop rivet them on. But since I assume, by your user name, you have an S or SL and not a 1978 Bronco I doubt that this is what you want.
Old Feb 9, 2003 | 01:56 AM
henry47's Avatar
asdf
Yeah, your wad is going to have to be pretty thick cause I hear it's going to cost you upwards of $2,000 to FLARE all your fenders.
Old Feb 9, 2003 | 03:53 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
u could try this
or a baseball bat...but that's real ghetto
Old Feb 9, 2003 | 09:52 PM
Swank500's Avatar
Thank You
I think I'll pass....
Thank You all very much....
Old Feb 10, 2003 | 10:36 AM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Adding fender flares is going to involve body work, smoothing and painting. Have you considered having the wheel well "rolled" instead? If you just need a bit more room to avoid rubbing an oversized tire or dropped vehicle, you might get it done with rolling the fenders, which is a lot cheaper and if done right, won't require repainting.
Old Feb 10, 2003 | 12:05 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Re: Flaring the fenders
Are you referring to "Fender Rolling"? This is not expesive:
Old Feb 10, 2003 | 05:02 PM
vraa's Avatar
can the dealer do all this?
Old Feb 10, 2003 | 05:33 PM
henry47's Avatar
asdf
probably not, but even if they did, they'll charge you an arm and a leg and plus a torso.
Old Feb 11, 2003 | 01:19 AM
Tezta's Avatar
CLS350
I believe Brabus charges any where from 250-350 just for fender rolling.
Old Feb 11, 2003 | 11:22 PM
vraa's Avatar
wow! i guess i'm stuck with 315 then
Old Feb 11, 2003 | 11:59 PM
henry47's Avatar
asdf
A lot of wheel shops will charge you less than $100 though. TWS charges MUCH cheaper than that.
Old Feb 12, 2003 | 09:48 AM
E55 KEV's Avatar
Veteran: Air Force
CRUCIAL - MAKE SURE THE TECH/SHOP KNOWS THAT THE PAINT MUST BE HEATED TO PREVENT THE PAINT FROM CRACKING. GOOD LUCK!
TireRack also loans out that Haweka Fender Rolling tool for 'free' with a huge deposit with video instructions and a heat gun. The list is usually long.
Old Feb 12, 2003 | 09:53 AM
Timster's Avatar
2011 GL450
I'm waiting to see the latest lotto winner! Yeee haaaaaaa!
Let's go mudd'n in my new SL.
LMAO,
Tim
