wheel sizes?
Personally, I would not go to the 17". I have the 16" E320 wheels on my 1991 300CE (Coupe), and 1989 300E (sedan), and they make the car look much newer, nicer & sleeker.
In addition to the size of the tire, you also have to look at the width of the tire as well. 245/45/18 is the same tire on my wife's S-Class. Going with a larger diameter tire will cause enough problems, but I suspect that tire would likely scrape your fender wells (if they even fit). There are more than enough options for decent / low cost MB (preowned) wheels & tires, with OEM quality, versus a potential unknown quality, fitment, casting, offset, etc.
Here is a pic of the wheels from 2000 - early 2002 W210 E-Class (slight variation was made through 1999 as well). I will see if I can find a pic of my W124 Coupe or Sedan with the same wheels & tires.
Separate pic of the alternate (slightly older wheel) W210 wheel posted as well. this is called a 10-hole wheelm annd was installed on W210's, up to 1999.
I have to keep on diggin to get a pic of the Coupe with the 16" MB wheels
I'm trying to install new wheels/tires that have a more sporty look. Thats why I was thinking a bigger wheel/tire. I see now I will need around the same size of wheel to fit the car. I would still like wheels like these:
You have a large pool of readily available wheels to choose from.
