Killer rear brake upgrade for CL203- all MBZ parts
Old Mar 13, 2003 | 08:03 PM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
In building our CL203 for competition we found an all factory way to get killer rear brakes. W210 E55 AMG rear rotors and calipers bolt directly to the W203 with no modifcations- period. Heres the stats:
W203:
10 7/8" rotor diameter
3/8" thick, non vented
2 1/4" x 1 3/4" pad
1 1/4" piston diameter
W210 AMG:
11 3/4" rotor diameter
7/8" thick, vented
2 3/8" x 2" pad
1 3/4" piston diameter
Buying the factory parts will cost you $1000 for everything- not quite as cool as a floating tuner brake set, but a nice alternative.
KLEEMANN has attached this image:
Old Mar 14, 2003 | 04:21 PM
peet's Avatar
09 C63
I assume you mean that this works on W203 C230 Coupes as well then?
Also - more importantly - if this works, what happens to the e-brake? I don't know the structure on the coupe's rear brakes but I would venture a guess that the ebrake works like a drum brake setup inside of the hat. Will this work still?
Thanks for the great find! This will help balance out the C32 front's in a big sort of way!!
Peet
Old Mar 14, 2003 | 04:22 PM
peet's Avatar
09 C63
Sorry - one more thing, can you post the 3 part numbers:
Pads:
Rotor:
Caliper:
Thanks again.
Peet
Old Mar 15, 2003 | 01:11 AM
OK Peet- Ill post the PN's- home for the weekend, so no access to my MBZ EPC to look them up. Ill catch you up on Monday.
ALL MBZ cars since 1998 share the same PB mechanism. This conversion is shown on a C230 (see pictures) so of course it works on it.
Old Mar 15, 2003 | 04:08 AM
Harris's Avatar
KLEEMANN: someone on the C32 board mentioned that the new E55 ( W211) brakes can be fitted on a C32. Do you have any information about it? Thanks!!
Old Mar 15, 2003 | 12:02 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Kleemann, on the inexpensive route I wish you or someone had drilled OEM replacement rotors for front and rear W210 E55. Brembo only has a rear drilled rotor for W210 E55 I believe, but no fronts.
Now that Kleemann offers a big brake upgrade kit for the W210 E55 with nice black calipers I am putting those on my wish list.
Old Mar 15, 2003 | 12:10 PM
Mach430's Avatar
We haven't tested the fitment, so I can only speculate on it. The SL55/CL55 brakes will not fit directly on the C32. If the E55 brakes are the same, which I presume they are, than they will need modifications to fit also.
The 55 brakes are also VERY heavy. Their mass is intimidating, but I think an aftermarket kit would probably have better results.
Old Mar 15, 2003 | 01:02 PM
The 8 piston AMG set will cross fit R230 and W211. The W203 and W209 are the same platform, they could share components.
Old Mar 20, 2003 | 12:47 PM
peet's Avatar
09 C63
So Uh whatever happened to the part #'s?
P
Old Mar 20, 2003 | 12:51 PM
Sorry Peet- with the 4 ft of snow we got over the last 2 days its been difficult. We are half staffed due to the weather and I persoanlly havent had time to look them up. I will post them when time permits later today-
Old Mar 20, 2003 | 01:51 PM
Here is the list:
