TPMS from Tirerack _ 09 C63 AMG
Old Apr 5, 2010 | 06:17 PM
all8up's Avatar
C63
Well I just recently put on a set of aftermarket rims and I bought new TPMS from Tirerack and ever since I have been getting an error message to check tire pressure. I called their CS and was told it had something to do with me parking near my old sensors? I would believe that but I was away the entire day yesterday and I kept getting messages. They also suggested to look in the owner's manual to see if there is a relearning process for the new TPMS. So far the only part I have seen is to use the current tire pressure as the new setting. Do you guys have any tips? I've reset the TPMS for the current settings at least 10xs and I have checked the tire pressure and they are at the recommended pressure.
Old Apr 5, 2010 | 11:03 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
Interesting... i have received 2 sets of TPMS from Tirerack and I have never had a problem. Are you sure your tires have the correct air pressure? I was using a cheap air gauge and it kept telling me that the air pressure was okay but once i switched to a higher tech one, i noticed that all my tires were wrong.
Old Apr 6, 2010 | 08:57 AM
all8up's Avatar
C63
I am running 41 & 45 (which is what the factory recommends for a 5 passenger car). I've been using this analog gauge for a while and I believe it is accurate. Additionally, I thought the TPMS worked by indicating if the tire pressure fell below the value that it was reset to. I have since reset this at least 10xs and I still get the message for "check tire pressure".
What are you running on your 19s? As you can see, I am using the 18" tire pressure.
Old Apr 7, 2010 | 10:04 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
kind of strange as we have set up thousands of Benz owners with sensors with little if any problems. How are the sensors mounted to the wheel?
Old Apr 7, 2010 | 10:28 AM
all8up's Avatar
C63
I am uncertain how they are mounted since I thought the sensors were integrated to the valvestem (which is the only part visible). I'm scheduled to go back to the tire shop on Thr night to have them fix a balancing issue. I would prefer to get this resolved at that time, rather than going back again. Any suggestions? I would think the only thing left is to replace them to see if this issue persists.
So far, I've reset the values when I was in my garage (within proximity of the old wheels, with the factory TPMS).
Reset the values when I was away from home the entire day.
Checked the tire pressure multiple times along with trying different pressures followed by doing the reset.
Old Apr 7, 2010 | 10:31 AM
what wheels are they?
Old Apr 7, 2010 | 10:56 AM
all8up's Avatar
C63
http://www.vorsteiner.com/Wheels/1PieceCast/CS-01.aspx#
Old Apr 7, 2010 | 03:31 PM
humm ...
make sure your installer didn't damage them during installation ....
if they still won't work after correct installation and lack of damage has been verified we will happily repaoce them and reimburse you for the labor to replace them
Old Apr 8, 2010 | 03:28 PM
all8up's Avatar
C63
I'll ask them to look at the TPMS tonight when they are checking the balancing issue. I only fear if they somehow damaged them, they may not be likely to admit fault.
Old Apr 8, 2010 | 04:27 PM
jamesdeanvegas's Avatar
02 mb c240
put nitrogen not air in them....makes a huge difference....
