H&R Cup kit on E430 disappointed...
98 E430
I just installed the H&R Cup kit, and its less than what I was expecting. I was expecting a really stiff ride, instead its still pretty soft.
Will Koni shock get me a stiffer ride?
TR Moderator & Tire God
depends on the weather
now .... let me understand this .... you are disapointed because the car has a very aggressive lowered stance and still maintains good ride quality .... and remember it is a proggressive rate spring which does stiffen more as it is compressed to increase your handling ability
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
I thought the Cup Kit was for the E320? If so, maybe the added weight of the V8 changes the performance & dynamics of the kit designed for a 6 cylinder E-Class.
2002 C230 : 2007 C230
Re: H&R Cup kit on E430 disappointed...
good point
98 E430
As with progressive springs, the more weight you put on it the stiffer it gets...well the V8 is definately more weight than the V6, and it's not as stiff as I like. Personally I think it's the shocks.
I recently test drove a Mitsubishi Evolution VIII, and I LOVE that stiff ride. It's a heart pounding, mind you not BOUNCING, suspension. I was hoping my benz will be CLOSE to that ride, rather it's still pretty soft for my taste.
Any forum members here that has a H&R/Koni combination in the LA area...I really like to feel that.
The H&R cup kit is working exactly as it should on your car. It is a soft ride on 320s and 430s. Just as the H&R springs for the 430 are the same as the 320 spring, you can use the 320 cup kit on the 430; even if others say otherwise.
If you want, I can arrange a time for you to meet up with Bruce (lowryder) and myself to compare the H&R/Koni combination and my H&R/Kleemann combination. Keep in mind, both cars are CLK's, but you can still get an accurate depiction of how it woudl feel.
98 E430
Okay, I'll give you a call maybe next week or week after. I am getting some other stuff done to the car the next couple of weeks.
I wanted to talked to you about tthe hi-flow manifold, and the pulley while I'm there.
2002 E320 Special Edition
Just curious. How does the H&R Cup compares to H&R/Bilstein Sport on a 2002 E320?
I have installed the H&R Sport/Bilstein Sport on my 95 M3 and it is exactly what I wanted. Good ride without too harsh on uneven pavement. Also, thanks to the Tirerack advice on selecting the Bridgestone S-03, a great tire on wet & dry plus excellent handling and ride, however, there is one major trade-off: steering response. Definitely not as sharp as the Michelin Pilot MXX3 that I had before (must be those stiff sidewall).
Thanks in advance.
Thanks in advance.
