Hubcentric Rings?
2002 S500
Hubcentric Rings?
I just got Carlsson wheels put on my 02 s500 and was told by the tire shop that the rear wheels were not hubcentric, what does this mean and where can I buy the hubcentric rings? The wheels are 19x8.5 front and 19x10 rear.
Thanks, Beau
Thanks, Beau
Most American cars are lugcentric, which means the lug bolts or studs hold the weight of the car. Our cars and many other European cars are hubcentric meaning the hub holds up the weight of the car. Different brands use different sizes of hubs. Since it would be very expensive to make wheels for these various sizes of hubs, the manufacturers make one wheel and use hubcentric rings in them to adapt to the differing hubs. The seller of the wheels should have provided these, if you purchased the from a retailer. You should be able to get the rings at most tire and wheel stores. If you can't find them, Tire Rack will have them. I wouldn't drive the car until you get them.
Tire Rack has a good explanation of hubcentric here.
TR Moderator & Tire God
depends on the weather
Just about all cars American or European or Japanese are hub centric form the factories in which that are made ... the reason for this is because lug bolts or studs with nuts do not have the strength to support the weight of the car. The center hub is there for that very reason.
C230 Sedan - 6 spd.
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I did a couple of searches for Carlsson hubcentric and found this thread. So, are they already hubcentric? I want to buy a set of 1/5 but need to know if i'll need to buy rings separately. Thanks!
Also, where's the least expensive place to get Carlsson 1/5 nowadays?
Thanks guys/gals!
Thanks guys/gals!
C230 Sedan - 6 spd.
According to this table link from Carlsson of UK, each Mercedes model seem to require different fittings. Eventhough Carlsson states that the wheels are made exclusively for MB? Does this mean each class has a different size hub?
More specifically, I'm looking at the Carlsson 1/5 for the C-class. The table denotes it as [2] which means that it should be fitted "professionally". Sounds like it would need hubcentric rings for the C-class. What do you think?
Thanks!
Thanks!
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Originally posted by E55 KEV
I thought all Carlsson wheels had MBZ 66.56mm centers and did not require centering rings at all?
I think it depends on who the manufacturer of the wheel is. This also seems to affect whether the wheel has ball seat or cone seat lugs... and my experience has been that the wheels with cone seat lugs require additional hubcentric rings. It could also be that wheels with fewer fitments available use a spacer, and the spacer is formed as a hubcentric ring so that it is easy to attach.
My 1/6 Evos use a hubcentric ring/spacer device, and cone seat lugs. My 1/5s are hubcentric out of the box.
-s-
