Fitment question about 20" Rims for a W212...
Old Feb 10, 2011 | 05:42 PM
DNAPoPo's Avatar
2010 E550 Sport Sedan Blk/Blk
Car is a 2010 W212 E550.
If you were to pick out 20" wheels what specs would be ideal in your opinions?
I'm thinking along the lines of:
20x9 et35 fronts with 255/30/20 tires
20x10 et54 rears with 285/30/20 tires
What would you guys change?
Thanks in advance.
Old Feb 14, 2011 | 12:19 AM
DNAPoPo's Avatar
Where are the wheel gurus?
Old Feb 14, 2011 | 02:18 AM
bighman's Avatar
2005 E55
I think the offsets for the rear may be too high...also rear tires should be 285/25/20
Old Feb 14, 2011 | 03:28 PM
DNAPoPo's Avatar
Yup, that is the correct size for for same diameter in rear, but I was actually told a 30 would fit, so I am leaning towards it for a smoother ride.
Old Feb 14, 2011 | 05:21 PM
ohlord's Avatar
ET wrong
tire sizes wrong
20's just plain wrong
And actually neither rear profile matches the dia.
the one you think would be smoother is more wronger than the other suggested.
Old Feb 14, 2011 | 05:28 PM
DNAPoPo's Avatar
Originally Posted by ohlord
tire sizes wrong
I guess it would help if you provide something more right instead... I'm open to any suggestions as I am no expert.
Old Feb 14, 2011 | 06:13 PM
ohlord's Avatar
Always test fit
But a 9 front on a 30-35et rim in 245/35/19 and a 9.5 on a 52et in 285/30/19
are within 1 rev of each other front and rear and 10revs per mile off the oem sport diameter.
There are reasons Mercedes did not use 20's and Your suspension etc. is not destined for them either.Proceed with caution if you do choose to go with 20's
your ride quality will vanish, handling will be compromised,and you will be dodging every pothole from La Jolla to Pacoima
You can always Email Luke at tirerack.com for fitment suggestions.
A 255 on the front might fit with fender rolling but why go there if not needed.
Are you planning on lowering the car?
Old Feb 14, 2011 | 06:17 PM
threeMBs's Avatar
Only MBs - the best or nothing
All the info you seek is already available by checking W212 forum. It contains many threads on the subject.
