Stepped lip 19" wheels and 8 piston 380mm caliper fitment
Old Nov 11, 2011 | 05:12 PM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
Hello everybody,
Just have a quick question that i hope some of you can answer. I know that quite a few of you on here run aftermarket wheels with the front 8 piston 380mm brake setup. I have a set of 19" Work wheels and am not able to test fit before buying so some advice would be appreciated.
I would like to know who is running a stepped lip 19" wheel up front with these brakes. A stepped lip 19" wheel makes it an 18" face and would like to know how the clearance is inside the wheel to the calipers.
thank you in advance
Old Nov 11, 2011 | 05:19 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
380mm = 14.96"
radius = 7.48"
19" stepped lip wheel inner diameter = approx. 16.5" - 17" at drop center
add caliper = doesn't fit
many 19's without a stepped lip won't even fit
not even close
Old Nov 11, 2011 | 05:35 PM
definitely dont want a 20" wheel.
my other option is an 8 piston front caliper with 356mm rotor which would give me another inch of clearance unless the 8 piston is too big than a 6 is next in line.
Old Nov 12, 2011 | 09:02 AM
19's without the stepped lip could possibly work .... but, the real question is why do you need massive 15" rotors and 6 or 8 piston calipers ...
if you want to post a link to profile for the brake kit you are looking at I could look into it a bit further
Old Nov 12, 2011 | 10:08 AM
i already had my wheels custom ordered earlier this year and am keeping the 19" stepped lip wheel. pm sent
Old Nov 12, 2011 | 11:32 AM
Glutes's Avatar
2006 CLK 500
Need to upgrade wheels
hey folks it's time to upgrade my wheels. I have a 2006 500 clk okay with stock 17 inch wheels I wanna move up to 19 inch wheels and I like the dub dirty dogs. what do I need to do to upgrade wheels to keep them from rubbing. Help!
Old Nov 12, 2011 | 11:51 AM
dub dirty dogs?
Old Nov 12, 2011 | 06:14 PM
Glutes's Avatar
2006 CLK 500
Originally Posted by sweet jones
dub dirty dogs?
Yes. DIRTY DOGS. Actually I found a nice three piece wheel with with a 5mm piece for the fronts and dumping the DD's. Good idea at first...
