Brand Newish Glazed Rotors - CLK55 '05
Old Sep 27, 2012 | 10:41 AM
Jesse Friedman's Avatar
I replaced my brakes 6 months ago. Rotors and pads for my 05 clk55 - rotors are slotted and drilled mercedes rotors and EBC redstuff pads. My brakes are pulsating now and the shop tells me that my rotors are glazed over and warping. Because of the slotting, they cannot machine the rotors. Any advice on what I can do to remedy this problem without having to buy everything again?
Old Oct 2, 2012 | 02:06 AM
Nero Tenebre's Avatar
W209 CLK Renntech Widebody, C140 CL600 V12, AP2 S2000, NSX Twin Turbo, R8 V10
It may be too late, but you should torque each lug nut down to spec with a torque wrench in a star pattern. This applies even pressure to the rotor (uneven torque usually causes warped rotors). Also, the pads should have been properly "bed in" which transfers some of the brake pad surface onto the rotor so they are mated. Good luck, I really hope that you don't need to buy it all again.
Otherwise...it could be the pads, have read a lot of negative reviews on those, do a search on it. https://mbworld.org/forums/w211-amg/...otors-wtf.html
