Pirelli PZero Nero Tires
I guess I got confused by Tireracks description and everyone's praise of the Pirelli tire. It looked like it rated the best for Wet & Dry and only good on snow, which obviously doesn't concern me in South Florida. Is the Continental ContiExtreme a better match for me?
Luke, thanks for exposing the truth about TireRack and shame on them for making up these numbers.
True, for all out max performance summer tires, S-03's, Pilot Sport (not A/S).
So what you are saying is that TireRack's numbers are totally made up. I knew it... I got the Pirelli P-Zero Nero M+S because Tirerack rated them higher than the Summer tire in every catagory from dry traction, comfort and wear. Damm, I wish I have gotten the summer tire and disregarded TireRacks made up numbers. Oh well, there's always next year.
I'm seriously thinking of the Goodyear F1 GS-D3's only because the thread pattern looks like it can't tramline because of the diaganol pattern and they are supposed to be quiet. I though about the Bridgestone S-03's which are a little cheaper but after this experience I don't want to take chances.
That's why it's rated better, it has to do with catagories. So a tire that is highly rated for handling in an A/S catagory can be worse handling than a lower rated tire in a High Performance catagory. That explains it. I can tell you that by far, the P-Zero Nero has to be the absolute worst tire I've ever had on any car or motorcycle. It truly handles very well and is reasonably quiet (except on concrete roads) but it's major flaw is that it tramlines, it follows the rain grooves on our So Cal freeways and makes the car shake from side to side like a railcar. Very disconcerting and I can't wait to take them back to the point that I'm driving a different car until I get a chance to return them. Pirelli said that they will take them back for that reason as they received simiar complaints before. They recommended the P-Zero Rosso but that doesn't receive high marks from many for noise and wear and many would not buy it again.
Those are the tires I'm thinking of. They are pricy at my local tire shop at $195 (otd) but probably worth it. There's absolutely no way they can tramline, the thread blocks are in a V shape from center.
http://www.tirerack.com/tires/tirete...tramlining.htm
These tires do not follow the expansion grooves between lanes like I've had on some tires in the past, to me that's acceptable but not a desireable trait. They are good in this regard, I can not detect lane expansion joint transitions at all. What happens to me is that when I drive on freeways in So Cal with rain grooves (purposely cut grooves about every 2" across the entire lane), the car actually has significant latteral motion, sort of like when you ride a train at high speeds and it shakes from side to side. I'm highly prone to motion sickness and it's to the point that I don't want to drive my car to work and take my truck instead. These are fairly new roads and are not rutted or defective in anyway, heck I-15 from Las Vegas I was on yesterday just opened the new section and that's where it was the worst. On the old parts of the road that were truly rutted like the above article mentions, it did not tramline at all.
These P-Zero Neros are all season tires, not high performance summer tires. I'm hoping the diagonal pattern of the Goodyears would be highly unlikely to exhibit this same traits as the P-Zero Nero.
Also I'm surprised they have rain grooves where it snows like MO. I would think that water would get in and freeze and crack the concrete.
Checked around the web and found that Toyo Proxes T1-S where specifically designed to reduce tramlining and several people on various forums switched to this tire specifically for this problem and it fixed it. It must be the diagonal grooves. I'll see if they are available locally.
