tires choice
I just got the wheels with the following setting I would like to know what is the correct tire pressure and what type of tire
I should get. I have a 2001 clk430 and drive mostly in SoCal L.A. area.
F - 8.5x19 235/35/19
R - 9.5x19 265/35/19
thanks
You shouldnt put 265/35/19 at the rear, the proper size should be 265/30/19.
Toyo T1-S has always been my favorite tire.
38 psi (f) and 36 psi (r) is a pretty good setup.
Is there a reason why Tire Rack doesn't offer a popular tire like the Toyo?
Definitely Toyos. The tread compound seems to be better than most. I went from Dunlop SP Sport 5000 to the Proxes TPT, BIG difference in both dry and wet handling, and a LOT less wheelspin around corners.
