Is rim weight a critical factor?
Old Apr 9, 2002 | 10:07 AM
DtS's Avatar
DtS
C200 Kompressor
Hi.
I'm in the market for a new set of rims for my W203. I've seen lots of threads discussing the importance of getting light rims (to decrease the unsprung weight). Why is this so important?
The rims I've been looking at is AMG Monblock II, ATP (AT Italia) Flash and ATP Benzis. I saw on www.tirerack.com that AT Italia (ATP Flash is offered, but how about ATP Benzis. I live in Europe and they are probably named differently here, but I couldn't find any similar looking rim in the "upgrade garage".
Can someone please explain why rim weight is important and provide me with weight figures for the following rims:
  • AT Italia Benzis (18x8)
  • AT Italia Flash (18x8)
  • AMG Monoblock II (18x8)
Thanks in advance!
An image of the ATP Benzis
Old Apr 9, 2002 | 12:46 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
something called unsprung weight. in a nut shell, sprung weight is weight of vehicle that is supported by the suspension. unsprung weight is weight of the suspension itself (e.g. wheels, springs, shocks, etc.). the more unsprung weight there is, the harder the suspension has to work. hence rim weight is important. as the suspension to move up and down, it needs to compensate for it's own weight. momentum is mass times acceleration; so the less weight, the easier it is for the suspension to move up and down. hope that helps.
Old Apr 9, 2002 | 05:51 PM
DtS's Avatar
DtS
C200 Kompressor
Thanks alot for your reply Steve S!
Ok now I've got they "physics" around my question, but how will for a heavy rim affect the performance of the car, like acceleration, top speed or handling. I now understand that the suspention has to work harder with a heavier rim, but it this really a bad thing (I the sense that one should avoid a heavier rim). Will for example the suspention wear much quicker etc.?
Old Apr 9, 2002 | 06:53 PM
steve s's Avatar
n/p
in real world? no...not really, u don't really have to worry too much about weight. most people do it for the looks . weight is therefore a secondary concern...unless u want to take ur car to the race track, where weight is everything, including the weight of the rim. of course, less weight is better. think about it, if u have a heavier wheel, that means the engine has to do just that little extra to start spinning the wheel so it can transfer the power to the ground.
for everyday use, and i assume u're going for the killer look on these 18" (17" should be quite enough to extract the great handling from a small car like the c200k), then you shouldn't have to worry too much about the weight. just use the weights as a guide if can't choose between the 3 by design (which, unfortunately, i don't have).
Old Apr 10, 2002 | 03:26 AM
DtS's Avatar
DtS
C200 Kompressor
Thank you!
I'm very pleased with both of your answers. My pimary purpose for a wheel upgrade would not be to decrease lap-times on a race track. I'm mainly interested in the looks. On the other hand, I wouldn't like to bargain to much of the performance (hence the original question). I will now, like you recommended, consider rim-weight a secondary concern.
Thanks again for all your help
Old Apr 17, 2002 | 02:52 PM
BrabusCClass's Avatar
GL450, Sienna SE
I like the Flash.
Old Apr 17, 2002 | 07:06 PM
Sleestack's Avatar
Re: n/p
I used to have 18" Brabus Monoblock V Multipiece rims. Those rims averaged 35lbs each. I switched to 19" BBS LMs which averaged 23lbs each. My car was noticeably slower off the line with the Brabus rims . My car seems more nimble with the LMs however, that might be psychological. Personally, wheel weight was enough of a factor for me that I sold my Brabus rims at a $2500 loss after 3 months of use. On the other hand, my wife would never notice. If performance is a big factor for you, consider weight. Also consider that there are some pretty nice looking lightweight rims out there.
Old Apr 18, 2002 | 03:58 AM
DtS's Avatar
DtS
C200 Kompressor
Thanks for your input Sleestack! Nice to hear some oppinions form someone who has had both heavy and light rims. So BBS rims are light (in general)??
Old Apr 19, 2002 | 01:12 PM
Sleestack's Avatar
I believe so. There is a website out there that posts wheel weights... if I can rememember where I saw it, I'll post it. Otherwise, just ask the company you are buying from about the wheel weight. Keep in mind that some of the light wheels out there are light because they aren't that strong. I would recommend going with a forged (as opposed to cast) wheel if you are looking for a combination of strength and light weight. Also keep in mind that I am driving a car that puts out over 480 hp and 450lb/ft of torque..... performance is first on my priority list. I think most drivers wouldn't care about the marginal perfromance differences a 12lb difference in wheel weight can make.
Old Apr 26, 2002 | 12:57 PM
oresama99's Avatar
M3 Cab
i think someone once posted that every pound of additional usnprung weight added equates to an approximate 2hp loss. so for sleestack, changing from Brabus to BBS would have slapped back on an estimated 24hp per wheel.
i know when i had my winter 15's on my a4 the car felt faster than when i ran my summer 17's. we'll see what happens when i get my 19's which may be lighter than the amg monoblock 18's. i will measure each wheel as i put them on and post the comparo.
Old Apr 26, 2002 | 06:35 PM
DtS's Avatar
DtS
C200 Kompressor
2 hp for each pound! Wow. Then rim weight is a critical factor after all!
Old Apr 26, 2002 | 11:46 PM
BruNo's Avatar
07' ML350
just had my 18" carlssons installed for almost a week now, and i dont c any difference in acceleration compared to my stock 16". The car doesnt lean as much, however the ride is bumpier than stock. So going bak to my question....what is the minimum recommentded tire pressure for 225/40zr18?????????????????
Old Apr 27, 2002 | 05:16 PM
oresama99's Avatar
M3 Cab
i always thought you are supposed to use the same settings as recommended by manufacturer. apply same psi from your 16's to your 18's.
