Dunlop Winter Sport M3 - run flat or not?
Old Nov 24, 2004 | 12:06 AM
noka's Avatar
'24 Porsche Macan
Any significant performance (or price) difference between regular and run-flat versions? Might be looking for Winter wheel & tire set (and I assume 7.5 x 17 recommended).
Rgds,
Norm
Old Nov 24, 2004 | 03:48 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
the cost of runflats is significantly higher fot the tire and if your car does not already have a TPMS (tire pressure monitoring system) you must add one and that is an additional cost (approx. $300.00) ... performance they are about equal
Old Nov 26, 2004 | 12:02 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
noka, winter tires don't come in run-flats!
Old Nov 27, 2004 | 08:53 AM
Kev, yes they do
Old Nov 27, 2004 | 10:07 PM
E55 KEV's Avatar
Veteran: Air Force
Thanks Luke, I thought "run flat" and "winter tire" was mutally exclusive. He-He!
Old Dec 4, 2004 | 10:22 PM
noka's Avatar
'24 Porsche Macan
Luke: Is the Dunlop WinterSport M3 size 225/45-17 only available as run-flat? I don't have TPMS and no plans to add one anytime soon to my C55. Otherwise, what alternate snow would you recommend in that size?
Note: I would typically drive the C55 on decent Winter days fairly clear roads, with only occasional inclement weather driving if I had to.
Rgds,
Norm
Old Dec 6, 2004 | 09:11 AM
my top choices (in order) would be
BLIZZAK LM25
BLIZZAK LM-22
PILOT ALPIN PA2
W210 SNO SPT
Old Dec 7, 2004 | 06:57 PM
noka's Avatar
'24 Porsche Macan
BLIZZAK LM25
BLIZZAK LM-22
PILOT ALPIN PA2
W210 SNO SPT
Interesting. Anything in particular make you choose Blizzak over Michelin? Is LM-25 a new model to replace LM-22?
Rgds,
Norm
Old Dec 8, 2004 | 12:09 PM
the Blizzak products offer better snow and ice traction .... and yes the 25 will replace the 22
Old Dec 8, 2004 | 03:38 PM
noka's Avatar
'24 Porsche Macan
Hi Luke, thanks for the info. I mentioned that I would typically be driving on days where the roads were clear (or at least plowed), with an occasional trip in snow covered roads. I do have a Winter beater but you never know when it could have a problem and the C55 must be called into service. Given that scenario, i.e. not driven every day (at least not in Winter) and also factoring in Winter tire wear on dry roads, would your recommended list above still hold?
Rgds,
Norm
Old Dec 8, 2004 | 05:02 PM
I understand but, you are only asking these questions because you are looking for winter traction
Old Dec 8, 2004 | 08:17 PM
noka's Avatar
'24 Porsche Macan
OK, fair enough. What is your rationale then for not recommending the Dunlop WinterSport M3, which by the TireRack survey results seems to surpass the others you mentioned. Again, not trying to be difficult, ... just looking for your opinion here.
Rgds,
Norm
Old Dec 8, 2004 | 10:14 PM
kort677's Avatar
'05 e320 cdi, '05 lexus rx330
BLIZZAK LM25
BLIZZAK LM-22
PILOT ALPIN PA2
W210 SNO SPT
And you don't list the Nokian hakkapeelika because???
Old Dec 9, 2004 | 08:36 AM
Rgds,
Norm
already out of stock for the season in most sizes ....
Old Dec 9, 2004 | 08:37 AM
we don't carry them
Old Dec 9, 2004 | 09:12 PM
noka's Avatar
'24 Porsche Macan
I got the LM25's.
