WTB hub centric wheel spacers
Info
I had Lorinser Hubcentric spacer and they did not work. The center diameter is close to 2.5 inches (66.5). I would say maybe 1.5 - 2.0 is what he might need.
When you have time confirm the center diameter. That way you can get a perfect fit. 12mm is close to half an inch. I don't think you had the 10mm eighter.
I think you had a 3mm one.
Here are some more but make sure you get the Hubcentric and that the middle diameter is the same.
http://shop.ebay.com/items/?_nkw=mer...cers&_osacat=0
You had to have the 3mm one because you were using the OEM bolts. With 10mm you would have had different ones.
3mm is .12 inches (point one two) so the stock bolts should fit.
They say
Both are for Mercedes center bore (66.5mm iirc) and 5x112.
The lorinser was 66.5 but it didnt work. Make sure if you ask the guy to measure it physically to be sure that they will fit.
Good Luck,
I felt bad you drove all the way out here and it didnt work.
The best is to physically see if it will work or not.
Good Luck,
But ya man, just go with hubcentric. You dont want to go on the cheap route and have problems down the line.
