Sponsored by: MB Part Haus
20" HRE THREE PIECE WHEELS - 20 x 9.5 , 20 x 10.5
Old Aug 20, 2009 | 12:10 AM
vwsnaps's Avatar
Volkswagen / Audi
I know i am new to this site, but i used this screen name on all sorts for forums.. vwvortex.com , porsche forums, audi forums, bmw forums..
Anyways.. 5 x 112 HRE wheels with out tires.
HRE
2 - 20 x 9.5 fronts
2 - 20.10.5 rears
5 x 112
2 sets of caps.
Original Metal caps with worn off logo
Cheap plastic reman's of caps
Wheels have nicks on some lips. 1 wheel has been welded / repaired for crack.. 1 wheels has some tape residue on center part of wheel.
Lots of pics.
$1500 + SHIPPING for the set ( for those that dont know, these wheels are $1995 EACH )
Link to more pics.
http://s169.photobucket.com/al...s/HRE/
Old Aug 20, 2009 | 12:18 AM
B. Gorman's Avatar
Former Vendor of MBWorld
2005 E500 Estate Wagon
Location and offsets (if you don't know the offsets, just post the numbers on the backs of the wheels)????
Old Aug 20, 2009 | 12:20 AM
soundeffects's Avatar
You have PM...I'll take them as long as I can call you before I pay for them and make sure they fit a E55 w211...
Old Aug 20, 2009 | 12:21 AM
vwsnaps's Avatar
Volkswagen / Audi
I have looked and looked , no numbers on back of the wheels... i was told ET35 but not sure that is right..
They were on an 2002 S55 if that helps? Ill look again to see if i can find some numbers on the back...
Nebraska..
I would trade for a late 80's cosworth project car...
Old Aug 20, 2009 | 12:23 AM
If there HRE's then they will have a serial number on them somewhere so they can keep track of the wheels.
Old Aug 20, 2009 | 12:26 AM
B. Gorman's Avatar
The serial number will be in the back-side of the hub (where the lugs go through). It should be about 12 digits and the front should be different from the rear!
vwsnaps's Avatar
Volkswagen / Audi
I will look in the morning / late morning and post em up.. I think there was a series of numbers that started 171 or something..
will serial number tell us offset?
Old Aug 20, 2009 | 12:30 AM
B. Gorman's Avatar
HRE serial numbers tell model,size,offsets, and widths...and how old the wheels are!!! There should be two on each wheel (a short one and a longer one under it). Please post them both.
Old Aug 20, 2009 | 04:31 PM
vwsnaps's Avatar
Volkswagen / Audi
Here are the numbers
Both wheels have the number
f - 46945 on the top
the front number is r5h20p306520
rear - r5h20p397025 ( or 825 or 325 ) hard to read the third to last number..
Old Aug 21, 2009 | 09:58 AM
B. Gorman's Avatar
The 46945 number lets you know that the wheels are about 3 yrs old.
The fronts are 20X8.5 (30mm offset)
The rears are 20X9.5 (39mm offset)
The 3rd to the last number is a zero (8 or 3 wouldn't make sense).
You probably measured them from the outer lip to the outer lip to get the width you came up with, but you should measure from the inside flange to the inside flange to get the correct width. If you call HRE and give them the numbers, they can tell you what specific car they were made for and when!!! Hope that helps.
Old Aug 21, 2009 | 11:01 AM
komp55's Avatar
ML550
Not to hate on HRE or these wheels, but HRE rims are VERY prone to bending. I've had two differnt sets of 19's and ended up dealing with multiple bent rim halves on both sets. HRE charges a small fortune to replace bent rim havles - the proper way to repair these. I would think used 20" HREs are a sure lock for being bent out of round. I finally gave up on HREs . . . they're pretty, but that's about the only nice thing I can say about them.
Old Aug 22, 2009 | 08:51 PM
There bought....Hope they work well.
