Sponsored by: MB Part Haus
FS or FT Socal 19" Original Mono Blocks
Old Aug 23, 2010 | 01:22 PM
kulitko1's Avatar
W202
So I have the 19" Original Monoblock Aero II that I would like to sell or trade. If anyone is interested, please let me know. Socal buyers only.
Specs:
Fronts are 19" x 8.5" ET 46 like new tires
Rear are 19"x 9.5" ET 46 need new tires
Old Sep 4, 2010 | 01:24 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
I guess, you decided to keep them after all for your W202?
Old Sep 4, 2010 | 01:48 PM
tomlchu's Avatar
1998 C43 AMG
im curious as to what these look like on a w202. you'd have to be running 15mm spacers front/back i think.
post some pics!
Old Sep 4, 2010 | 04:07 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
post some pics!
You will definitely need spacers for the front and back to run a ET of 46, you might be able to get away with 10mm spacers but I am not sure
Old Sep 4, 2010 | 11:03 PM
Jovsky's Avatar
post some pics!
Here's a pic of Kulitko1's W202 with 19" Monoblocks : https://mbworld.org/forums/4233380-post1345.html
Old Sep 7, 2010 | 01:07 PM
kulitko1's Avatar
W202
Actually the back fit just fine... the front need 3mm spaces since it wouldnt clear... but all in all it really looks good =)
Old Sep 7, 2010 | 01:29 PM
Jovsky's Avatar
Originally Posted by kulitko1
Actually the back fit just fine... the front need 3mm spaces since it wouldn't clear... but all in all it really looks good =)
James, since you needed 3mm spacers for the fronts, did you need to change the OEM bolts for the fronts with longer ones? Or the same OEM bolts will still do? Also, what are your tire sizes for both the fronts and the rears? Thanks!
Old Sep 7, 2010 | 02:04 PM
kulitko1's Avatar
W202
Yup you are right... I actually had to get longer bolts for the front and back since these Mono blocks had a different offset. I had to get a 5mm longer bolts for them.
As for the tire size:
Fronts are 215 35 19
Rears are 225 35 19
