FS- 19" Leon Hardiritt Ritters 2 (19x8.5 et39 fronts & 19x9.5 et42 rears) : PA or VA
All four wheels have recently been refinished. They were completely disassembled, and cleaned. lips were machine polished and barrels were scrubbed. Faces were stripped and powder coated in a two stage cast iron with satin clear finish. All bolts, nuts and holes were cleaned and re tapped before installation.
Wheels are 19x8.5 et39 and 19x9.5 et42 The centerbore is 66.56mm
One of the fronts has a replacement barrel. This wheel also has the valve stem passing through a bolt hole due to the location of the stem hole. The other front has a 1" weld on it from an earlier repair. See pics.
Asking $1,500. I will ship the wheels at buyers expense or I can meet in the DC or Philadelphia area. Feel free to make an offer, but I am in no rush to sell these wheels so please be considerate. Shipping will be via Fedex Ground. Email or Post for a quote.
http://www.flickr.com/photos/jowensmith/5726568340/sizes/l/
http://www.flickr.com/photos/jowensmith/5726011877/sizes/l/
http://www.flickr.com/photos/jowensmith/5726011959/sizes/l/
http://www.flickr.com/photos/jowensmith/5726012029/sizes/l/
Looking over on the SLK forums for offsets (since I don't own one) they list a 19x8.5/9.5 combo fitting with an offset ranges of et30-38 front and rear.... looking on this thread, link he has a 8.5 F/9.5 R with an et38 and they fit fine,,, so...
the fronts would just clear, though a small spacer might be required or desired to get the wheel right out with the fender line, I would say 3mm -5mm. Same goes for the rear, but your looking at a slightly larger spacer.. prob in the area of a 7mm-10mm spacer.
test fit on a dark grey B8 A4... as you can see, it really brings out the blue in the color....
What size of tires should be using if I want to stretch it?
