Sponsored by: MB Part Haus
18" BBS LM reps $529 NEW from Powerwheelspro
Old Dec 11, 2012 | 12:50 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
Description: BBS LM style wheels
WHEEL SPECIFICATIONS
Price: $529
Size: 18x8.5 (18x9.5 also available, add $20 in purchase price)
Offset: 35mm or 45mm
Weight: ~24lbs
Hub size: 66.6mm (hub rings included)
Bolt Pattern: 5x112
Finish: Silver Polished Lip
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrations or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Old Dec 11, 2012 | 09:17 AM
lbmazdaspeed's Avatar
2009 c300 4matic P1
I am wodering if you have a set that would fit a c300 sport? Looking for a staggered setup wheels and tire package? And if so is silver the only finish you have? I did see a gun mental finish on one of the pics. Thank you
Old Dec 11, 2012 | 09:33 AM
E320
Hi there,
We do have the fronts in 45mm and the rears in 35mm.
The finish is all Silver Polished Lip, the color discrepancy is due to lighting conditions.
We can certainly do a wheel and tire package for you. Did you want any tires in particular? All season? Winter? Once we have some more information I can send you a couple of quotes.
Regarding fitment, we have done the 45mm front and 35mm rear and the car turned out very nice, no poke in the rear.
I confirmed with this wheel/tire calculator using 18x8.5 45mm in package one and 18x9.5 35mm in the second package:
http://www.rimsntires.com/specs.jsp
Clearance:Package 1Package 2SuspensionAssuming that this is OEM wheel/tire and there is no any problems with clearance on both sides >>>100% clear (leaves even more room than OEM) FendersPackage will stick out 10 mm (0.4'') farther. Acceptable for most cars. WheelwellsThe same.
Old Dec 11, 2012 | 09:55 AM
2009 c300 4matic P1
I am looking for all season tires, so would it be 18x8.5 front Et 45 and 18x9.5 rear Et 35? I want a staggered setup, would the stock TPMS fit these wheels, I am really interested, also do i use stock lugs or do you sale the correct ones? thank you
Old Dec 11, 2012 | 10:15 AM
E320
We can do any of the following in 225/40/18 F 255/35/18 R all mounted and balanced in addition to the wheel price.
General G Max $728
Kumho Ecsta 4x $620
Hankook Ventus V12 $728
The wheels will work with your TPMS sensors and you can use your stock bolts. You can either swap out your sensors or we can ship the wheels with new ones, they are about $55 a piece (x4).
Finally, for wheels and tires shipping goes up from $85 to $140 as it is a bigger, heavier package. On the bright side you can install them on your driveway.
Please let me know if I can be of any further assistance,
Old Dec 11, 2012 | 11:36 AM
2009 c300 4matic P1
Talking
Last questions I promise, do these wheels come with the BBS caps, if not do you know where I can buy them? lastly what the best way to purchase the package should I just call you or online? thanks
Old Dec 11, 2012 | 11:57 AM
E320
No problem, you can ask as many questions as you need, I understand buying wheels is an important decision
The wheels will ship with the red BBS center caps.
You can either purchase online or you are welcome to call us at 248 686 2035 to place your order over the phone. Or we can send you a paypal invoice, whatever is easiest to you.
Thank you,
Old Dec 11, 2012 | 05:39 PM
jonwc32amg's Avatar
2002 c32 amg
Do you have these in 19 s for a c32 thanks
Old Dec 11, 2012 | 11:14 PM
E320
Hi jonwc32amg, unfortunately those are currently available in 18...
Apologies for your inconvenience,
Old Dec 13, 2012 | 12:33 AM
jturkel's Avatar
02 C32 AMG
will these 18s fit a c32/clear the stock breaks? any possible fitment issues or near for spacers?
Old Dec 13, 2012 | 09:42 AM
E320
To honest with you jturkel we have not tried it. We can ship you a front if you like to test it. The rears will work no problem.
If it works and if you like it we will process the charge for the other 3 and ship them to you. If not we will send you a label to ship it back and give you 100% a refund for the wheel.
We are willing to work with you to make sure you are out no money.
Thanks,
Old Dec 14, 2012 | 11:18 PM
BaDiNfLuEnCe55's Avatar
2004 m3, 2005 e55
How many inches is the 9.5 lips
Old Dec 15, 2012 | 03:53 PM
E320
The rears have a 2" lip
It is sort of a step lip:
Old Dec 15, 2012 | 04:00 PM
E320
Here are a couple more
Old Dec 15, 2012 | 04:03 PM
E320
The front and the rear lip has an inch difference. Front TOTAL lip measuring from the rivets is 2" and the rear is 3"
The additional width is on the first step.
Old Jan 3, 2013 | 09:55 PM
amante's Avatar
c230wz
Same question on these my man. Will they fir a w203 c230 with sport package?
Old Jan 3, 2013 | 10:18 PM
E320
anything 8.5 wide with 35mm offset will most likely need a 5mm spacer to fit over the AMG calipers on the W203. We do have them in stock and they are guarantied to fit.
Thanks,
Old Jan 4, 2013 | 04:27 PM
E320
Hi Pete S,
You are right, you will need a 10mm spacer for your R129 SL.
Regarding tires, we can do 245/40/18 F 275/35/18 R either Hankook Ventus V12 or the new Nitto Inbo for $804 mounted and balanced.
We do have the longer bolts that you will need for your spacers, 40mm ball seat for an additional $20 for the set of 20.
Shipping is $140 for the wheels and tires, so your total would be $1493 delivered. Extra $20 if you wanted the bolts too.
Regarding the center caps the wheels come with the red logos from the factory. They have adhesive in the back and they stick on the blank center cap. If they are not to your liking you might be able to find different color ones on ebay or something.
Just an idea
Thanks,
Old Oct 16, 2013 | 01:02 PM
marquisalley's Avatar
2004 C240 4Matic
PM Sent
Old Oct 16, 2013 | 04:32 PM
E320
Thank you marquisalley, pm replied
Old Oct 28, 2013 | 12:53 PM
TTR's Avatar
TTR
R129 SL500 & W140 S500
529 for a set of 4?
Old Oct 28, 2013 | 07:40 PM
Peydidy's Avatar
C63 AMG
Could you PM me information on a set for a 2009 C300?
Any other colors available ? Do you have them in 19s also?
Will I need hub rings also? Stock bolts fine?
Old Oct 28, 2013 | 10:06 PM
tc1728's Avatar
2008 E63 fitment?
Old Oct 29, 2013 | 01:17 AM
E320
Hi azn.ttr,
Yes the price is for a set of 4
Peydidy,
We do have them in 18x8.5 Black with Polished lip in 18x8.5 42mm, or in Silver with Polished lip in 18x8.5/9.5 35mm. The 42mm works better on your W204.
tc1728
Yes we do have them in staggered fitment for your car in 18x8.5 20mm F and 18x9.5 28mm R. They are specially made in low offset to clear your brakes. I personally don't know anyone else who has them available in those specs, let alone at that price.
New pics posted below
Thank you,
Old Oct 29, 2013 | 01:19 AM
E320
Sorry Peydidy, I forgot to respond to your other questions.
The wheels are hubcentric and they will work with your stock lug bolts.
Unfortunately no 189s at this point in time.
Thank you,
