FS 20" HRE 840R SoCal
Hello,
I have some cool wheels for sale.
Wheel: HRE 840R
Size: F: 9x20 ET31 R: 10.5x20 ET35
Tires: F: Falken 458 255/30/20 R: Nitto Invo 295/25/20
Condition: Wheels are basically BNIB condition. They were refinished about a month+ ago. Tires are great, I would guess about 75%. Center caps are brand new courtesy of ACG SD. Look at the first pic, the inner barrels are as clean as they were leaving HRE. The rest of the wheel is in the same condition. If you are fussy about your wheels, these will make you proud.
The wheels are located in Los Angeles. I will ship no problem, just have to work out the details.
Price: $3500
Wheel: HRE 840R
Price: $3500
^ Tire Rack has S class wheels ranging on offset from the 40's to 38 in the rear and in the mid 30's for the front. With these wheels, you should be flush. With that said, the S does have some wide fenders so it may actually fit perfect.
To give you an example, I'm running a 7mm spacer in the front, and a 15mm spacer in the rear and there's still room for more. If you look at the last two pictures I posted you can see I can easily squeeze another couple mm in the front and rear.
Also bump!
Also bump!
CLK63 AMG Black Series, Maserati Quattroporte Sport GTS, Porsche GT3, Mercedes G55
