widest wheels for a w203
Former Vendor of MBWorld
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
If I remember correctly, the widest tires that will fit on the W203 would be 255. But I could be wrong.
Haha I would but I'm getting work wheels. 11 in the rear lol ill sticl with 9 infront because I dont want it to damage my bags if not ill get them made to 8.5
I know we were able to fit 19x9" with 3" lips and 19x10" with 4" lips on 225/35 and 245/35 tires on ours! The fronts just clear our AMG brakes though, and with 2 degrees of camber they just fit!
More can be seen here >
19x11 on the rears with a max of a 6inch inner barrel and depends on your spoke curvature and pad depth....'every wheel design is going to fit different' I never pay attention to offset........
on the front depending on the wheel design and my car is a C55 I have Schmidt Vn Lines which have a very curved spoke which allows me to run a ..
19x9.5 et22
V3 hub pad
6" inner barrel
3.5" outer barrel
no spacer, no body work needed and a flush fit no poke with no negative camber...
my rears are...
19x10.5 et29
V2 hub pad
6" inner barrel
4.5" outer barrel
once again flush no poke, no body work, no spacers no negative camber, I wanted to do 5" outers but I did not want poke or wanted to add any negative camber....keep in mind X brand or design wheels won't get the same fitment even with the same specs because it with have a different center
19x9.5 et22
V3 hub pad
6" inner barrel
3.5" outer barrel
my rears are...
19x10.5 et29
V2 hub pad
6" inner barrel
4.5" outer barrel
New to fitment and offset info.
Hoping to revive this thread and get some input.
Looking to buy a set of wheels and the fitment i need to go with would be 17x9 35 offset in the front on 235. In the rear im looking at 17x9 and a 22 offset.
Was hoping i wouldnt have any issues with touchin the brakes.
Id just worry about going up a tire size in the front and then I cant use a spacer to get me away from brake contact.
Any input would be awesome.
