DEPO c63 Style headlight condensation
2012 C300
I just installed a brand new Depo headlight and its keep getting moisture on both headlight. I read few threads that it'll go away in about 2 weeks. is this true? or is there something wrong with this headlight? is there something i could do? any advise? thank you
2012 C300
its been 2 days since i installed it and i still see condensation. but the weather has been cold and raining. could the weather affect it from fully drying out? its freaking annoying.
Where did u get those headlights? I have seen a few on eBay. Didn't see any of them comes with HID options. Those condensation usually disappear when it stop raining. Those depo headlight didnt have cap on the back ?
2012 C300
https://www.uniquestyleracings.com/i...te=common/home
The condensation will make them even more authentic, The MB ones steam up quite a bit but it's not considered a fault according to the handbook.
2010 C200 CGI
You can pull the light off and either use a hairdryer on low setting to evaporate the condensation or a long tweezer with a cotton ball dipped in alcohol and wipe it down, depends on where the condensation is. While the light is out, run silicone along the entire edge of the housing where the lens meets the back unit to seal it up completely. I had this problem before with other depo lights and this is how we solved it.
Well...I just took the plunge and purchased a set of DEPO headlights. I'll be sure to report whatever condensation I experience, but living in SoCal where it hardly rains, it may come few and far between compared to east coast climate.
Thanks Knightmare on the silicone advice, I did see that in another thread and I am definitely going to do that.
2010 C200 CGI
Once you lay a bead of the silicone on the edges, make sure to flatten it down some for maximum coverage. While Depo goods are usually made well quality wise, they seem to have an issue with their sealant.
