C63 AMG (W204) 2008 - 2015
DIY LSD fluid change ?
Old 06-14-2013, 02:51 PM
mrl0n3ly714's Avatar
SLK 55, CLS 550, C63
I have c63 performance package and the manual say I need to do it at 2000 miles and every 40milea after that,
Went to dealer yesterday and he pulled the record and previous owner did not do LSD fluid change at 2000 miles, the car is at 37000 miles
I bought the vacume Mytivac to do oil change and
Is there a instruction how to do LSD fluid on performance package?
Also there is special fluid ? Do you guys know what part num ?
I searched forum but couldn't find any DIY on LSD package
Also what is diff on LSD on performance package vs LSD non performance package
Old 06-14-2013, 03:36 PM
esses's Avatar
2013 P31 C63, 2014 Bluetec ML, 2004 GT3
i plan on changing mine out every 10k miles or every track season. the dealer quoted me 1/2 hour of labor and appx $100 for fluid. from what i gather, the OEM fill is a very good fluid and no reason to change from it. i am sure you can pick some up at your local dealer.
Old 06-14-2013, 06:23 PM
BLACKONBLACKC63's Avatar
c63amg
I will have my Wavetrack differential install tomorrow. Will try to take some detail picture for you on how to do it.
It has two plugs, one on the bottom will be drain plug and one on the side will be refill plug.
You will fill the differential up until it spilling out and that all. Prop take a 2 quart.
Old 06-14-2013, 06:27 PM
awesome cant wait
Old 06-14-2013, 11:06 PM
bhamg's Avatar
C63 AMG
Re the fluid:
https://mbworld.org/forums/c63-amg-w...do-we-use.html
Old 06-15-2013, 06:43 PM
MY understand is,
unplug the drain and let it drain,
pull the fluid on the other plug using oil tube or something...
so can i reuse my plugs or i have to replace it ?
Old 06-15-2013, 06:56 PM
c63amg
I reuse both of my drain plug. I just clear the up and apply silicon before i put them back in.
The differential take about 1.5 quart. You will see it spilling out when it full.
[IMG][/IMG]
[IMG][/IMG]
There are two picture i took for you.
Good luck.
Old 06-15-2013, 07:25 PM
thank you, that was easy, thought it was a hard job and dealer wanted 100$+ for it
Old 06-15-2013, 07:45 PM
c63amg
It super easy. Totally DIY friendly.
I guess we dont call them stealership for no reason.
Old 02-10-2014, 04:08 PM
shams51's Avatar
C63 507
the dealership just charged me 176$ for the change stealership it is
Old 02-21-2014, 12:46 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
There are several threads giving fluid spec, source and diy
Quick Reply: DIY LSD fluid change ?
