Rear diff oil change
Hey everyone
I was under the car and noticed the rear diff plug leaking so I might as well do an oil change on the diff and replace the plug.
What kind of oil does everyone recommend and why??
Cheers
Cheers
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Depends on if you have an LSD or regular open diff.
LSD = Castrol Syntrax Limited Slip 75W-140
non-LSD = https://mbworld.org/forums/c63-amg-w...ml#post6580478
Also see this thread - cheap and effective mod while you're in there. https://mbworld.org/forums/c63-amg-w...l-cooling.html
The following 2 users liked this post by Jasonoff:
BLKROKT (01-05-2020),
silversleeper48 (06-12-2019)
Dude see the link above
posting this in here because i didn't want to start a new thread
the 2 plugs drain/fill are required to be replaced with brand new ones? locally i'm getting quoted $40~ a plug... that's gotta be some advanced plug...
I changed the diff oil twice in my 2010 and just reused the plugs. They did not leak at all. Just snug them up and don't over tighten them. Two to three wraps of teflon tape should help seal them up if you are worried about leaks.
thanks. that's what i did as well. hopefully it holds up
I changed the oil in my non limited. the plugs went back in and don't leak. However, it developed a small swat/leak at the rear cover gasket.
I'm going to try to re-torque the cover bolts.
Getting to that gasket may mean having to drop the diff.
I've just bought an 09 C63. How can I tell if the car has a LSD? There is no mention of it in any of the paperwork I got.
Regarding the differential fluid change, I did a flush today and it took just over 1.5L, I purchased 4 small bottles of the Castrol each 500mL (original from the dealer) and my mechanic told me most of the forth bottle was left.
Get your VIN decoded for your options. You can find online, or if you contact MB USA customer support they will email it to you for free.
