CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC Malfunction - Stop the car now(CL63)
Old 11-23-2016, 05:09 AM
GMBALL's Avatar
S63 COUPE M157
Since it got colder I have been driving my car not as often, about 2-3 times a week with each drive about 20 miles. Today, after 3 days of sitting I wanted to drive it to my office. First 10 minutes everything was all right, then yellow warning "ABC Malfunction" came on. I thought just an error, stopped the car, switched of the engine and went outside = ride height was fine, no problems. Started driving again, after about 10 minutes another message came on "ABC Malfunction - Stop the car now" in red color. Managed to get it right to the local MB dealership, which was 2 minutes from where this happened. When I stopped the car and looked at it from outside:
1) smoke from the engine (hydraulic fluid everywhere in the engine)
2) ride height dropped dramatically on front right side
3) hydraulic fluid under the car
I think a hose or something like that. Wonder, how much this will be. Will keep you informed as soon as they call me.
This is a photo of a yellow message, which was 10 minutes before everything went ultra wrong.
Old 11-23-2016, 11:39 AM
Dr Matt's Avatar
05 CL65
Hope the pump is OK. When you get the red "stop car now", it means NOW.
Old 11-27-2016, 06:29 AM
GMBALL's Avatar
S63 COUPE M157
Car is fixed, it was ABC Hose, the cost of material was 350USD, labour was about 250USD. I guess I was very lucky.
Old 05-22-2021, 12:35 PM
Martin V's Avatar
Mercedes CL63 AMG
ABC malfunction
Hi guys i have question about ABC malfunction on my CL63 2012
I will give me a yellow error ABC malfunction when I stand running on P for a long time I will classify D and after a few seconds I will give me abc malfunction you can not advise me what the problem may be? did it before changing the set of abc oil and the filter
thank you for the information
Old 05-23-2021, 06:18 AM
Vahebaldemian's Avatar
2009 CL63 AMG (CL55 AMG Kompressor previous vehicle)
Check your hydraulic fluid!
Checl the level of the fluid immediately! Also check the color. Alot of times, the yellow light alone can be a warning for low fluid and a simple top off can prevent further issues. Also to the original poster, ive haf to deal with the same issue. Luckily in both our cases, the pump was not damaged.
Old 06-19-2021, 03:31 AM
Martin V's Avatar
Mercedes CL63 AMG
last reply
+ when my abc malfunction error pops up the only thing that doesn't work for me is the real front abc shock absorber
when i pick up the car all work except the right front
can you advise me what could be a mistake
and
error code 5105 right-hand front suspension arm plunger check valve
biker349 (06-19-2021)
Old 05-09-2022, 10:06 AM
vervuurt's Avatar
CL550 AMG package
Originally Posted by Martin V
last reply
and
Did you get a solution? Mine has the same problem.
Old 05-09-2022, 12:09 PM
Martin V's Avatar
Mercedes CL63 AMG
yes you need buy brand new velve block
this type cannot be repased, you need to buy a new one and if you have a model before, it can be repased
this is facelift valve block
https://abcteile24.de/en/produkt/ven...r230-r231-neu/
Old 05-09-2022, 12:11 PM
vervuurt's Avatar
CL550 AMG package
Look at that price... OMG
Old 05-09-2022, 12:55 PM
Martin V's Avatar
Mercedes CL63 AMG
do you have cl63 5.5 biturbo?
I'll try to write to my service man I had a better price there and one piece if you were interested
Old 05-09-2022, 01:09 PM
vervuurt's Avatar
CL550 AMG package
I have a 216.371 CL500/550 2006 euro model, which started as 2007 in USA. W216
Old 05-09-2022, 05:20 PM
Martin V's Avatar
Mercedes CL63 AMG
do you have air matic suspension no abc in my opinion or???
Old 05-09-2022, 05:31 PM
vervuurt's Avatar
CL550 AMG package
I have the complete AMG package. Full package. ABC suspension.
Old 05-09-2022, 05:47 PM
Martin V's Avatar
Mercedes CL63 AMG
So you have to buy it all velve block
on abc teile 24 have repased velve block with the price 1000€... this velve block its to much
but since I exchanged it so there has been no problem so far so I am satisfied!
there is no other way
Old 02-05-2024, 09:01 PM
Warmachine20's Avatar
Mercedes benz cl 63
ABC malfunction
2008 Cl 63 hello chat I had my car for 2 weeks I left it running next thing smoke coming from front end and a pool of fluid smh i had it towed to mechanic ill definitely keep you posted on cost of damage.
Quick Reply: ABC Malfunction - Stop the car now(CL63)
