HELP! Instrument cluster
HELP! Instrument cluster. SOLVED!!!! 14-12-2015
Hi,
yesterday when trying to add fuel tank info to cluster (witch i did) some how i lost the automatic gear box shift info on both sides of Km info in bottom of the cluster. How can i get it back? Please help. I've tried several kinds of coding but none where successful. Thanks
EDIT: forgot to say that i have a w211 2004 car
Did you touch anything else than 'tankinfo im...' option? I believe there is options for selector display too, but I cannot see how they would have changed if you just put tank info visible and reset IC...
Well i touched a bunch of things but the selector display disapeared before i got to developper part and switched tankinfo. I'm a bit newbie in DAS/xentry so i'm trying to learn as much as i can. I think the slector display was gone after i "coded" the IC version, by default one of the menus shows not configured and you have to select version of IC, MY2003, 2004, 2005, etc. I tryed to recode with some of this versions (2006 included) and couldnt get selector display back.
Developer mode changes takes place usually after reset only, so your 'version' change may have done the reset automatically and default values are used. I'll check my star tomorrow in simulation mode if I find correct parameter/option. I think you need to go to developer mode now to change display... I saw you have thread 'in the dark side' forum too, they are pros using DAS and other tools...
Yes i have lol. hope u can help me. But latter on i'll at home again and i'll retry to fix too. One thing that i must do (we all should) it's to translate from germain to english. Dam germain is hard to understand
Lol, I have read German about one year, unfortunately does not help much with these technical words...
Hmm just surfing in star sub-menus....
Have you tried all possible model years now? I think you must select correct MY in any way (see your car data card)... did you press default version coding under control unit adaptations - version coding? That may have changed something... I still don't get it why default would be no gear display
See what is your current status (sorry about english terms, Im using my own language and have to guess how they are translated in english) in factory diagnose - control adaptation - version coding - variantenkodierung werkseinstellungen - Vereinheitlichte Ganganzeige aktiv/passiv... at least that sounds it has something to do with gear display, just dont know what exactly 'unified' here means and what that option does...
I've tried a few yes. I spent a lot of time translating all the options in development. I found that one too, the only one apparently related to gear box display. I'll try latter on tonight again. Here is the translation (google one)
aus - out
ein - on
manuell - manually
nicht erlaubt - not allowed
nicht - not
erlaubt - allowed
alt - old
nachleuchtzeit innenlicht - Interior light afterglow
scheinwerferaufschaltung - headlight intrusion
tagfahrlicht - daytime running lights
einheit wegstrecke - unit distance
einheit aussentemperatur - unit outside temperature
automatische turverriegelung - automatic door locks
auswahl anzeige in statuszeile - Select display in status bar
Vmax-begrenzung(winterreifen) - Vmax limit (winter tires)
sprache - language
audiomodus - audio mode
anhängerverlustwarnung - Trailer Grain Loss Warning
spiegeleinstellung - mirror adjustment
umschaltung 12/24 - switching 12/24
einstellung datum - setting date
umfeldbeleuchtung - ambient lighting
klimatisierung lenkrad - Cooling steering Wheel
druckeinheit - printing unit
fahrdynamischer seitenhalt fahrer - driving dynamics lateral support driver
ambientes licht - ambient lighting
taxi-dachzeichen - Taxi roof sign
fahrdynamischer seitenhalt beifahrer - driving dynamics lateral support passenger
taxi oder privat - taxi or private
schlüsselabhängigkeit - key dependence
spiegel anklappen - folding in mirror
heckdeckel - trunk lid
sommer/winterzeitumstellung autom - summer / winter time changeover Auto
abblendlicht - dimmed headlights
wegstrecke - distance
außentemperatureinheit - outside temperature unit
automatische türverriegelung - automatic door locks
anzeige in statuszeile - display in status bar
aussentemperatur - outside temperature
geschwindigkeit - speed
anzeig im grundbild - ad in the main screen
einstiegshilfe - access aid
zuheizer - heater
anzeige uhr - display clock
werkseinstellungen - default settings
komplette tankdatensätze - complete tank records
komplette texte für datenfunk - complete texts for radio data transmission
reiserechner - trip computer
variantencodierung menü-werkseinstellungen - variant coding menu factory settings
variantencodierung schlüsselkonfig - variant coding key config
manuell über konfigurationsmenu - manually via the configuration menu
heckdeckel öffnungsbegrenzung - boot lid opening restrictor
vorzeitiger abbruch gurtwarnung - Premature discontinuation seat belt warning
kein vorzeit. abbruch - no past. demolition
kein vorzeitig. abbruch - no Prematurely. demolition
vorzeitig. abbruch - prematurely. demolition
vorzeit. abbruch - prehistoric. demolition
gurtwarnung - Seat belt warning
ab motorstart - from engine start
nicht vorhanden - unavailable
vorhanden - available
bsg warnungen - bsg warnings
darstellung status zv-notöffnung - Display Status ZV emergency opening
aux bedienbarkeit bei KI15Raus - aux operability at KI15Raus
wecken über lenkradtasten - wake on steering wheel buttons
uk-variante - uk version
einheit tacho-skala - unit speedometer scale
vreg fahrerbedienung in statuszeile - VREG driver's operation in status bar
uhrsynchronisation mit HU - Clock synchronization with HU
außendisplay - external screen
sprachfunk - voice radio
möglich - possible
tankgeberfestsitzerkennung - Fuel sender fixed detection
tankgeberfestsitzerkennung mit x gebern - Fuel sender fixed detection donors with x
einstieg in service menü - entry into service menu
cancel-taste - cancel button
abhängig von eventmaske - depending on event mask
unabhängig von eventmaske - regardless of event mask
kontroll-lampe (nur bis vorserie) - indicator light (only up to pre-production)
anzahl tankgeber vorhanden - Number of fuel sender available
gurt - belt (cinto)
gurt akustik - belt acoustic
handbremse - and brake
lichtwarnung - light alarm
art-info bei lampentest - art-info at lamp test
gurtwarnung display - belt warning display
tempomat - cruise control
v-reg signale vom id 210 auswerten - evaluate v-reg signals from the ID 210
lichtwarnung autom. fahrlicht - light alarm Auto. Driving light
bremswarnung - breake warning
dämpfung bargraphen - bargraph damping
verdecksteuergerät - convertible top control unit
abbruch der schlüsselwarnung nach 30s - Demolition of the key warning after 30s
epc displaymeldung - epc display message
darstellung des hintergrundsymbols - Presentation of background symbols
klappbox warnungen - folding warnings
reifendrucküberwachung - tire pressure monitoring
vgl-displaywarnung - see display warning
vgl-lampe - see lamp
kurvenlicht warnung - headlights warning
datumsanzeige grundbildebene - date display basic image plane
bremsbelagverschleißwarnung - Brake pad wear warning
rußpartikelfilter warnung - particulate filter warning
vereinheitlichte ganganzeige - unified gear indicator
tachokennlinie - tacho characteristic
mobilitätskonto - mobility account
k-zahl - knumber
tachokennliniensymmetrie - tacho characteristic symmetry
symmetrisch - symmetric
unsymmetrisch - asymmetrically
rücksetzintervall - reset interval
eeprom-wert - eeprom value
darstellung geschw.-warnung - representation Velocity warning
tankinfo im reichweitenbild - tank info in Range image
menü RR: reichweite/tankinfo - Menu RR: Range / tank info
exception handler lampe - ExceptionHandler lamp
bild unterspannung - Picture undervoltage
bild überspannung - Picture Surge
wegstreckeeinheit für tachorückstellung - distance unit for tacho reset
verbrauchsanzeige km - consumption indicator
ölstandsanzeigen - oil level display
schalter - switch
fernlicht erlaubt - fernlicht allowed
kraftstoff filter warnung - fuel filter warning
reiserechner anzeige bei reserve mit - trip computer display with reserve with
strichen - painted
werten - cheap
wasser im kraftstoff warnung - water in fuel warning
KI ist programmiert, sommerausgabe - KI is programmed summer edition
einheit dtr-skala - unit DTR-scale
tankdeckelinfo - tank lid info
gwsz-vorstellung - gwsz concept
tankreservewarnung - fuel reserve warning
nicht definiert - not defined
serviceanzeige - service display
ölstandsanzeige - Oil level indicator
ölsensorwarnung - oil sensor warning
darstellung text aus eeprom - display text from EEPROM
elektrohydraulisch bremse - electro-hydraulic brake
wartungsrechner expertenmodus - maintenance computer expert mode
segmentring - segment ring
format datumsanzeige - format date display
wartungsrechner werkstattmodus - maintenance computer workshop mode
bedienhinweis fds - operating note fds
sollwert - setpoint
aus - out
ein - on
manuell - manually
nicht - not
erlaubt - allowed
alt - old
sprache - language
zuheizer - heater
möglich - possible
gurt - belt (cinto)
k-zahl - knumber
schalter - switch
strichen - painted
werten - cheap
sollwert - setpoint
The following 4 users liked this post by pedroenf:
Problem SOLVED!
Just figure it out. It was a wrong programing of the ZGW (or CGW). The items that concerns to the transmition were wrongly coded, CONFORT transmition was existent when it should be INEXISTENT. Only AUTOMATIC TRANSMITION should be EXISTENT. After changed, the gear display pops up in the cluster (no need to reset KI). Somehow i must have changed the CGW coding the first time.
The following 2 users liked this post by pedroenf:
Aqidi Mohammad (11-18-2021),
nivram13 (08-16-2017)
Like in other post, also fault could be in gear selector module, TCU communication, KI, ZGW, EIS...
is it possible to enable on cluster oil temperature-lap time and battery icon like AMG?
aus - out
ein - on
manuell - manually
nicht - not
erlaubt - allowed
alt - old
sprache - language
zuheizer - heater
möglich - possible
gurt - belt (cinto)
k-zahl - knumber
schalter - switch
strichen - painted
werten - cheap
sollwert - setpoint
aus - out
ein - on
manuell - manually
nicht - not
erlaubt - allowed
alt - old
sprache - language
zuheizer - heater
möglich - possible
gurt - belt (cinto)
k-zahl - knumber
schalter - switch
strichen - painted
werten - cheap
sollwert - setpoint
LJurys (12-03-2022)
Can you check the proccess? I checked all the das cluster but I couldn’t find it...
QUOTE=Mackhack;7298055]I did it for a lot of people. This is nothing you do with your Star Diagnosis though.[/QUOTE]
Can anybody tell me the right w211 ignition-on can comands ??
I have searched the web but nothing found.
I have tested
ID = 0x000 with 1 byte 0xFF.
These seems not right for ignition on ?????
Many thanks in advance
I have tested
