SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: cost of lowering r129
Old 10-27-2008, 03:39 PM
thompson12001's Avatar
sl 500
Hi all. I'm a neewbie here so forgive the stupid question. I was looking into purchasing some lowering springs for the r129. I was wondering what I should expect to pay in terms of installation fees from a mechanic. I was quoted $800 a few days ago from a shop in San Francisco. I've lowered cars in the past and they usually charge $100-300 for the install. I realize the r129 is a big car but still, $800 seems really expensive. Any suggestions? Thanks.
Old 10-27-2008, 05:23 PM
Bigdot's Avatar
some
its a lot. and the camber is always off afterwards. i dont remember the cost of mine, but it was not to cheap!
Mark
Old 10-29-2008, 12:32 PM
Lincoln's Avatar
97 SL500
My shop quoted $400 plus alignment ($150) to install Eibach springs...I have not done it yet but will if I decide to keep the car.
Old 10-29-2008, 12:44 PM
Bigdot's Avatar
some
thats a great deal!
Old 11-13-2008, 11:29 AM
Jim's500E's Avatar
If you can borrow/rent/buy an internal spring compressor, its really quite easy to change out the springs. Shocks also are easy and can be done in the driveway.
Def a trip to MB for an alignmnet afterwards.
Old 11-23-2008, 06:03 AM
lynns's Avatar
2000 SL500
I just bought a new set of Bilstein's for $355.00 shipped and a new set of H&R Sport springs for and eBay price of $371.00 delivered. I will be using #1 shims up front and #3 buffers in the rear. I was quoted $450-$600 for install less alignment that I will do about a month later when the car settles and I put new rear tires on.
I'm glad it was my favorite Indy that will charge me the $450.00 for the above. He also quoted me $340 to just change the springs.
Note: the H&R springs will drop the car about 1.5" so it's important on older 129's to adjust the position of the 'rear axle limit switches for the roll-over bar' to function properly. Then test the car by driving forward and braking real hard at about 7 MPH to get the roll-bar to accurate. I'll let you find out how to retract the bar after that? Do some reading!
Old 12-11-2008, 11:44 AM
starbai's Avatar
2004 S2000, 1992 Prelude
Do these cares generally require camber kits after lowering? or will a standard alignment usually take care of it?
Old 12-11-2008, 11:54 AM
lynns's Avatar
2000 SL500
Originally Posted by lynns
I just bought a new set of Bilstein's for $355.00 shipped and a new set of H&R Sport springs for and eBay price of $371.00 delivered. I will be using #1 shims up front and #3 buffers in the rear. I was quoted $450-$600 for install less alignment that I will do about a month later when the car settles with the hardtop on and new rear tires.
Note: the H&R springs will drop the car about 1.25" so it's important to adjust the position of the 'rear axle limit switches on older 129's for the roll-over bar' to function properly. Then test the car by driving forward and braking real hard at about 7-10 MPH to get the roll-bar to accurate.
I would suggest that you take advantage of a MB Special Dealer priced 'regular alignment' for about $90.00 because of the 1.25" drop. I'm not talking about a car that's been slammed and needs a camber kit.
Old 12-20-2008, 02:04 PM
gqmagic's Avatar
96 SL500, 97 E420
I hope you have not paid that much for springs and labor, A fair price is $500 or so, A great price is $420 here in So Cal orange county.
Old 01-26-2015, 07:02 PM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Rear spring shims 1994 SL320
Can some one tell me if a 1994 SL320 uses rear spring shims? I'm going to use HR springs and Bilstein B4 in the front and B6 shocks in the rear of my SL320 1994. I see spring shims being used #1 front and #3 or #2 in the rear but I can only find front shims for this car.
John
Old 01-26-2015, 10:17 PM
lynns's Avatar
2000 SL500
John
Thats because the rear shims are known as BUFFERS.
Please see Rear "Buffer" p/n's
Old 01-27-2015, 12:35 AM
FATHERTIME's Avatar
Thanks for the fast reply
I found the buffers at the site you mentioned this site looks like a good source for my car
Old 01-27-2015, 01:24 AM
lynns's Avatar
2000 SL500
You might get better pricing and availability at your local Merc Parts Counter and if you want to return something they will usually work with you. Or you may want to use www.oediscountparts.com. Shipping is free if you buy greater than $50.00 and there total pricing w/ ship is better than parts.com
Have you thought about the following parts from the list at http://www.benzworld.org/forums/5653276-post1027.html while your installing new struts and springs?
Strut Mounts (2 each Mercedes-Benz) p/n 1243200473
Strut Bump Stop (2 each) p/n 1293230744
Strut Boot (2 each) p/n 1293230192
Front #1 shim (2 each) p/n 2013210984
Rear #3 buffer (2 each) p/n 2013251144
The above 4 items from your local MB parts counter total about $35.50 + tax.
Always read the "POLICIES>SHIPPING POLICY" fine print and make sure to supply your VIN when ordering online.
Old 01-27-2015, 01:50 AM
lynns's Avatar
2000 SL500
Please consider saving yourself some money by going with B4 (Comfort / Touring Class) shocks ALL the way around. I think you'll enjoy a better ride.
Old 01-27-2015, 01:58 AM
FATHERTIME's Avatar
I can't find this p/n "Rear #3 buffer (2 each) p/n 2013251044" to be listed as a fit on the SL 320, am I missing something?
Old 01-27-2015, 02:02 AM
FATHERTIME's Avatar
I already have the shocks and springs if they're too stiff then at least pretty easy to change compared to springs, i got all 4 from Shock Warehouse for $467.00
Old 01-27-2015, 03:22 AM
FATHERTIME's Avatar
Old 01-31-2015, 09:56 AM
FATHERTIME's Avatar
I'm confused on the spring shims, where as I'm using HR springs lowering the rear 1" and front 1.3" the #3 shim is 18mm thats .7" so does that mean I'll only lower the rear .25"?
Old 01-31-2015, 10:26 AM
lynns's Avatar
2000 SL500
I'm confused on the spring shims, ...
Try not to get to hung up on the shim/buffer mm size difference because they are not what lowers the car. They only buffer the ride and level out the car from front to rear by a small fraction of what the total drop is. The H&R springs cause the drop.
Use a #1 shim on the front and #3 buffer on the rear. Trust me that your car will look and ride just fine.
8mm#1-18mm#3 = 10mm = 0.40" difference from front to back
Old 02-03-2015, 08:22 PM
FATHERTIME's Avatar
Question
8mm#1-18mm#3 = 10mm = 0.40" difference from front to back[/QUOTE]
Ok I have all the parts now, shocks, springs all new shock mount components along with the eight links in the rear plus new sway-bar links. I plan to have it done in a few days, Does anyone know of a good alignment shop for this car in Orange County CA?
Old 02-04-2015, 12:44 AM
lynns's Avatar
2000 SL500
Call for cash pricing and appointment for a Vehicle Alignment Report at
Costa Mesa Brakes & Tires
2945 Randolph Ave., Unit C
Costa Mesa, CA 92626
714-557-1322
Note: pay attention to your Final Rear Camber. It should be close to -2.0 degrees after your lowering springs are installed.
Old 02-09-2015, 11:03 PM
FATHERTIME's Avatar
The job is done and ready to go for alignment. I guess if I'm using wheel spacers to bring the tires flush with the fenders I need them on the car for the alignment? The rear needs about 36MM spacer and the front needs about 25MM but I'm having trouble finding front spacers. Any help here will be appreciated.
Old 02-10-2015, 03:39 PM
lynns's Avatar
2000 SL500
It sounds like you need the right size ET for your rims instead of spacers. Please see http://www.benzworld.org/forums/3036558-post11.html for the right size offset = ET for the 129.
Old 02-21-2015, 10:17 AM
FATHERTIME's Avatar
Can you tell me what the toe should be for the rear? I wound up with camber at -1.9 and -2.2
Old 02-21-2015, 10:33 AM
lynns's Avatar
2000 SL500
Look at your Alignment Report Specifications.
That's what my car read
Quick Reply: SL/R129: cost of lowering r129
