190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Chevrolet Power LSX
Old Sep 4, 2019 | 10:46 PM
6PointO's Avatar
W116 w201
Chevrolet Power LSX
long story short I bought a 6.0 out of a 2500 Silverado, then bought a 1985 190e roller the day after, car is super clean except the interior is roached. Once I got it back to shop I started cutting the car apart to jam the v8 in. 3 months of progress photos incoming.
Old Sep 4, 2019 | 11:29 PM
6PointO's Avatar
W116 w201
Cut out a ton of metal to make room lots of cut off wheels and grinding but got the subframe and rack where I want it
Old Sep 4, 2019 | 11:43 PM
6PointO's Avatar
W116 w201
Started out with a Muncie that we had sitting on the shelf. I thought a 4 speed would be fun till I realized the shifter came up about 10” to far forward. Glad I had it tho since it was great for mock up and making motor mounts. Also found out that the truck intake was about 6” to tall.
Old Sep 4, 2019 | 11:51 PM
6PointO's Avatar
W116 w201
Bought a ls1 intake manifold and a T56 which cured my shifter location and hood clearance
Old Sep 5, 2019 | 12:04 AM
6PointO's Avatar
W116 w201
The steering rack was a pain to get right but for now it will have to do. Will probably change this down the road but gotta keep moving. I found it easiest to get rid the stock column and make my own shaft and supports.
Old Sep 5, 2019 | 12:09 AM
6PointO's Avatar
W116 w201
Dropped the old subframe out and had a scion FRS complete subframe that I made mounts from the chassis to bolt in. Lots of cutting and beer. Still need to mount shocks but it’s 90%
Old Sep 5, 2019 | 12:15 AM
6PointO's Avatar
W116 w201
Cooling system almost all plumbed.
Old Sep 6, 2019 | 09:55 AM
alexasa's Avatar
c
awesome!
Old Sep 6, 2019 | 11:18 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
SICK!
Old Sep 7, 2019 | 09:10 PM
Street2speedway's Avatar
Too many to list all
Rack angle
Hows the rack angle? I have a similar set up but had to pull it apart. Once i lowered the front the rack was hitting my a arm. If i moved rack higher it was hitting my ls oil pan. In process of switching to c5 suspension because of this. And running rear sump. Some pics of rack angle would be nice to see and compare.
Old Sep 7, 2019 | 10:07 PM
chassis's Avatar
2017 GLE350 4MATIC
Cool. When do you fire it up?
Old Sep 7, 2019 | 10:18 PM
6PointO's Avatar
W116 w201
It’s got a little angle and pretty close to the lower arm. I’ll take pictures next time it’s on a hoist
Head gaskets, flywheel and fuel pump away.
Old Sep 7, 2019 | 10:20 PM
6PointO's Avatar
W116 w201
One more 90 degree bend and the cooling and intake set up is done.
Old Sep 17, 2019 | 11:15 PM
Headers
Whats the plan for exhaust, Im planning on mine, but mot much room to run big pipes down the car. Really not many header choices either, thinking of custom welded header?
Old Feb 16, 2020 | 03:31 PM
6PointO's Avatar
W116 w201
car is up and running.
Old Feb 16, 2020 | 03:41 PM
6PointO's Avatar
W116 w201
Video of car running
Old Feb 16, 2020 | 05:39 PM
Good job!
Old Mar 23, 2020 | 10:51 PM
6PointO's Avatar
W116 w201
Finished up the engine bay just have to paint bottom of hood. Also got some bbs rs that I am finishing up restoring
Old Mar 23, 2020 | 11:00 PM
6PointO's Avatar
W116 w201
car rips. No traction in 2nd, it’s great.
Old Apr 9, 2020 | 08:40 PM
6PointO's Avatar
W116 w201
Fitted a w126 speedo into the w201 cluster. Speedo and rpm work perfect.
