Average oil consumption ??
I am purchasing a 1991 W201 190E 2.6 in the coming days. Vehicle has just shy of 199,000 miles. Drove it yesterday and for its age and mileage it appears to be very solid. No major rust. Owner states that it uses oil mainly to leaks. I plan to do oil analysis after I bring it home. Question…what is the average oil consumption to those that know for this old timer Mercedes?
Even if it was maintained like my car. What wears a properly maintained engine is cold starts. I am burning about 1 quart/500 miles at 200Kmiles. I am the original owner and know the history.
My car has been started cold 40K times, used <5miles per trip for 30 years. Same mileage that was driven 20 miles per trip will last a lot longer. Probably over 300K miles.
BTW I have already had the head re-done, guides, valve seals etc. I am convinced it is the piston oil rings (worn). Will need a engine overhaul at some point. Currently just add oil once a month.
No compression issues whatsoever.
In your case if the engine never had the valve guides done, that will improve matters by a factor of two.
Also, there is no oil making its way into the intake thru the breather hose. Super clean there too.
So it is not the compression rings.
After this and the compression and leak-down tests I have conducted, and also the observation of the condition of the cylinders during the head job when it was removed (with all the honing marks still in tact) my conclusion is that either the oil rings are worn or stuck letting oil into the cylinders. Oil burning is rather even in all cylinders, meaning the spark plugs get fouled evenly on all 6.
BTW, I have flushed the engine twice to see if I can release the oil rings, and unfortunately, the oil burning went from 1000mi/qrt down to 500mi/qrt. So all the build-up in the piston rings/cylinders must have been helping with the oil burning. Wish I had not done the flushes.
I will only know for sure once the engine is opened up. Currently the engine (and garage) is occupied with my son's Miata Engine rebuild. So we wait....
- Cheers!
- Cheers!
And the engine flush made it worse by a factor of two.
I will only know when I pull the engine some day. Till then we just add a quart every other fill up....
Have any idea how many highway miles on your car?
Interesting that the dealer opted to replace the entire head assembly when the gasket blew in 2004. So, it would be on its second head gasket at this point.
I just did a cylinder head swap last year on my green car, but in that case the machine shop had a refurbished head ready to go that he needed to dump.
